06-02-2012, 03:21 PM | #1 |
Rep 165
expiring CPO & extended maintenance
My CPO & extended maintenance expire in 2 weeks on my '06 MR. I'm about a thousand miles from inspection 1 so I'm planning on sending her in to the dealership the day before expiration as I will be within a couple hundred miles at that time and have the insp 1 done. This spring they replaced the rear brakes and did a brake fluid flush as well right after I took her out of storage.
Is there anything else I should be asking the dealership for on this final trip? |
06-02-2012, 06:29 PM | #2 |
Accidentally in BMW
15
Rep 221
I know this seems obvious but make sure you book and appointment and not just "show up". That close to the wire... you just might "accidentally" miss the window.
Even my indy is booking 2-3 weeks out. Cheers. |
06-02-2012, 06:33 PM | #3 |
Rep 704
Drives: '08 MC
I had my power steering lines checked and replaced.
Check motor mounts/bolts Check rear swaybar mounts Obiv make sure they do the valve adjustment correctly (drop off the night before) what else.....
06-03-2012, 08:27 AM | #4 | ||
Rep 165
Thanks for the tips. When they did my last inspection they listed the various shim part numbers & quantity used right on the paperwork. Beyond that I'm not sure how I would verify they are doing the work correctly. Did they changed the PS lines under CPO or did you have to pay for that? If so, how much? |
06-03-2012, 08:30 AM | #5 | |
Rep 704
Drives: '08 MC
Also - check your "M Mobility Kit" in the back by the battery. the flat tire kit. If its expired, they should replace that too.
06-03-2012, 03:27 PM | #6 | |
Rep 165
