      08-06-2020, 09:20 AM   #1
SwissArmy
Why so serious?
SwissArmy's Avatar
[RESOLVED] Is it possible to code out the Headlight Level Sensor?
Hi guys,
I recently developed a code with the headlight vertical level sensor. I had a new one handy, so I decided to go ahead and replace it.
At first, the code was 34 vhac front load sensor lsz
After replacing the sensor, and clearing the codes, the 34 code disappeared but I now have two new codes:
30 control unit error in VHAC-part
31 stepping-motor defect
I've tried clearing them in INPA but they come back as soon as I start the car. Do I need to drive around first?
EDIT: driving around did not help
Important notes:
- the little plastic arm on my sensor has been broken for 6 years but this error only showed up a few days ago
- the replacement is a brand new headlight vertical level sensor, aftermarket/non-OEM
- I do not need the headlight sensor as I am running Spyder HID headlights
- I am lowered on ST coilovers
My car came with factory Xenon headlights which I've replaced with Spyder headlights. I understand the Halogen headlights do not use a headlight level sensor.
In that case, should it not be possible to code out the level sensor altogether? If so, how?
Your help is always appreciated
      08-07-2020, 08:34 AM   #2
SwissArmy
Why so serious?
SwissArmy's Avatar
Anyone with coding experience?
      08-07-2020, 12:24 PM   #3
Clearancediver
Drives: 2004 Z4
You would need NCS Expert/NCS Dummy at a minimum to look at the appropriate module.
You should read up on this software and it's abilities... as well as figuring out what module you will need to access.
Sent from my smart phone...
      08-07-2020, 10:30 PM   #4
SwissArmy
Why so serious?
SwissArmy's Avatar
I already have NCSExpert. I guess I'm not really sure what to do/look for. I tried watching/following some tutorials. I know it's part of the LSZ module. I was hoping if someone has a definitive idea of how to get to that and what to look for
      08-08-2020, 10:35 AM   #5
Clearancediver
Drives: 2004 Z4
It's been quite some time since I used NCS Expert... I did however download the radio module software into NCS Dummy where I could save module coding as a separate file.. then make the required change and save back to car. That way you still have original file to reload if you did an "oops"....
You likely will need the coding from a car that has the headlights that you installed. But the coding in your car may give an option to make the sensor code line... nicht actif ... if I remember the German right, and that line of code exists in the version of the LMZ software loaded.
SwissArmy140.50
      08-08-2020, 09:32 PM   #6
maupineda
Drives: E86 Z4MC
You replaced the headlights, the car is looking for the OE electronics, which you removed. You will need to spend time and trial and error.
Search changing the vehicle order and remove xenons, that may help, but even the halogens have the leveling system, is just manual, so it may still throw a code.
      08-08-2020, 10:25 PM   #7
SwissArmy
Why so serious?
SwissArmy's Avatar
I've had these headlights on for years, and no error code has shown up until a few weeks ago.
Regardless, I grew some balls and learned about NCSExpert and went in and decoded the sensor. No error code/light anymore. All good now
Thanks all
wdb4732.00
      08-09-2020, 12:56 AM   #8
Clearancediver
Drives: 2004 Z4
Brave man... not easy doing your first coding... Glad it worked out for you.
      08-09-2020, 07:21 AM   #9
SwissArmy
Why so serious?
SwissArmy's Avatar
Thanks man! I will share which lines I've altered at some point today to help anyone else that is facing a similar issue
