      08-02-2020, 11:23 AM   #1
Oldmcst
Drives: 2004 BMW Z4 3.0I
Help removing stuck CD
A CD is stuck in my '04 3.0I. I've tried the used CD flip out method, tape on a credit card method, depress the off/on button and eject button at the same time, (ignition on and off), all to no avail. I hesitate to try to remove the radio even though I've seen the How To video. Fortunately, I have a good Boney James CD in there and it still plays.
Any other suggestions without taking it to a pro?
Thanks to any responders.
      08-03-2020, 02:20 PM   #2
wdb
dances with roads
wdb's Avatar
4732
My wife would be mortified to know that it is a Boney James CD!
Good luck.
      08-03-2020, 03:38 PM   #3
Oldmcst
Good luck.
At least I can play it over and over. Always good!!!
wdb4732.00
      08-06-2020, 09:47 AM   #4
SwissArmy
Why so serious?
SwissArmy's Avatar
Removing the radio is not a daunting task, thankfully.
You just need to remove the vents (two tabs at the top that depress using a flat head screwdrive and pull out)
Then two phillips screws holding in the radio. Once it's out, leave the cables connected. Aim the radio downwards and press eject and try to use gravity along with the motor to get it out.
Else, try needle nose pliers?
      08-06-2020, 06:00 PM   #5
Oldmcst
Worth a try!! Thanks very much!!!
      08-08-2020, 04:03 PM   #6
Oldmcst
I got the radio out w/o much difficulty. Even after turning the radio upside down and shaking it, nothing happened. The crazy CD still plays while upside down!!!
I'm done messing with it.
Thanks again to all helpful comments!!!!
      08-08-2020, 04:18 PM   #7
wdb
dances with roads
wdb's Avatar
4732
Now that you have it out, check the ads for a replacement unit?
      08-08-2020, 10:31 PM   #8
SwissArmy
Why so serious?
SwissArmy's Avatar
Or take it apart. There are a few "BMW Business CD Disassembly" guides on on the net/YouTube. If you're going to replace it, I would try disassembling it first. If you fail, you can still replace it.
EDIT: When you press Eject, do you hear the ejection motor turning/making noise?
wdb4732.00
      08-08-2020, 10:38 PM   #9
SwissArmy
Why so serious?
SwissArmy's Avatar
https://www.youtube.com/watch?v=B4F39lF2pqk
wdb4732.00
