      06-28-2021, 11:59 AM   #1
Ranger_Vet68
Ranger_Vet68's Avatar
Drives: 2003 Z4 3.0i E85 Roadster
Head Unit
I have a 2003 BMW Z4, and I'm looking to purchase a new head unit for my car where I can load at least 6 cd's simultaneously and has an AUX port for use with an iPod.
Thank you.
      06-28-2021, 01:26 PM   #2
Clearancediver
Drives: 2004 Z4
It's called a cd changer and the wiring to attach is in the trunk to front area bulkard…..
Realoem.com is a resource for part numbers etc
Sent from my smart phone...
      07-03-2021, 12:47 AM   #3
Ranger_Vet68
Yes, I understand what a CD changer is. I don't want to buy something I don't need when there are head units out there that do the same.
      07-03-2021, 12:52 AM   #4
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
If you have a seperate amp, an aftermarket unit won't be able to work with that amp. (at least not to my knowledge, maybe something custom can be rigged up but I reckon that requires extensive knowledge from both the wiring, BMW WDS and maybe Ibus and Kbus system)
So that is something to take into account.
Maybe a BMW audio specialist knows more.
      07-03-2021, 04:40 PM   #5
Clearancediver
Drives: 2004 Z4
There are 3 radio systems that BMW uses in that year of car. I have a high end Carver DSP 10 speaker system. Only the basic radio and HiFi systems are capable of using an aftermarket radio.
Run your VIN to find d we hitch system you have. You can also see if you have DSP settings available via the left hand buttons. Only the basic 6 speaker radio system is plug and play with aftermarket radio. Think HiFi system has some things you need to do extra… Carver system is a complete gut/replace including speakers because of BMW using non standard impedance speakers….
Google and have fun…. Or not…
