10-03-2012, 06:53 PM | #1 |
Rep 1,034
Do keys go bad? Hard time starting car.
Can the keys fail? I've been having a hard time getting my car started. I put the key in and everything turns on, but when I turn it, the starter wont go, like the clutch isn't pressed, it takes a few tries but it eventually starts. I even went so far at so replace the starter (80k, it was time anyway) had the battery tested and it's still strong. On a whim I tried the other key and it's been starting fine every time. So is it probably the key, or maybe something in the car? How hard is it to get a new key?
10-03-2012, 07:05 PM | #2 |
Rep 1,107
Why don't you continue to use the other key for a while, just to prove that it's the key. I would particularly see if it always starts on a day when you are in and out of the car often. If it passes that test, then I would think the key (either the key was mechanically worn or something to do with an immobilizer) was the culprit and get a new one.
10-03-2012, 08:18 PM | #3 |
Rep 1,034
Well yea, I'm going to use the other key and make sure that is indeed the issue. I was wondering if this was a common thing.
10-03-2012, 10:22 PM | #4 |
Rep 615
My son's car wouldn't start and the Indy found out that the chip in the key wasn't communicating with the computer to allow the car to start. Turns out that his key went through the wash in his pants and this probably damaged the chip in the key.
10-04-2012, 12:01 AM | #5 |
636
Rep 3,124
Thanks for the tip and the reminder.
When I bought my car used, it didn't come with a spare key. If mine goes through the wash or in the pool, I'm toast. Searching for "spare key" thread ... |
10-05-2012, 01:41 PM | #7 |
Rep 1,034
I wouldn't think it'd be the battery. I've had my second key go dead from non-use. It still started the car even when I had to re-pair it to the car to get the remote working again. I did send my 'main' key through the wash once, but that was quite a while ago.
10-05-2012, 04:41 PM | #8 |
Rep 615
It was several weeks or months after my son's key went though the wash that he started having trouble using it to start his car.
10-05-2012, 08:31 PM | #9 |
Rep 33
If you take your registration to a BMW Dealership they will make you a new key for $200.00.
10-06-2012, 08:45 AM | #10 |
Rep 2,138
Drives: Me
Key facts:
BMW makes 10 keys for each EWS (immobilizer) module. If you use all those keys up you will need a new EWS module. (according to BMW) The dealer does not 'make' you a new key. You provide a valid ID, valid registration with VIN number (both must match) and anywhere from $150.00 to $250.00. The cost is dealer dependent. The dealer then contacts BMW USA and orders a new key based on your VIN. The battery internal to the key is primarily for the remote locks but is also used as a backup to the EWS power tap. The ignition lock has a circular antenna that 'beams' power to the key and interrogates the internal key transponder allowing the car to start. It also recharges your key battery. The internal key batteries are not made to be 'user replaceable'. You CAN cut open a key and unsolder a battery and replace it but most will owners do not have this capability to do this. |
10-06-2012, 12:56 PM | #11 |
Rep 1,107
Wow, that's a ton of very useful information. What that means to me is that I should periodically swap the key that I use so they both stay charged.
One question, what is the EWS power tap, what does it do, why would it need a backup power source and what good would a backup power source if the powertap's primary power source was dead? |
10-07-2012, 10:00 PM | #12 |
Rep 1,034
A dead key battery shouldn't prevent you from starting the car. It's only for the remote.
