      11-27-2010, 07:46 PM   #111
HOG4DNR
HOG4DNR's Avatar
Drives: 2014 M235i
This thread is starting to read like a soap opera, not that I watch soap opera's.
I'm learning alot, (not being sarcastic).
2008 Z4MC #1786/1815 "The Last IB w/ Extended Leather Made" Gone but Not Forgotten
2014 M235i E.Blue Mods in Progress
      11-28-2010, 03:18 PM   #112
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Originally Posted by just2talented View Post
Its edited because im keeping the vehicle. Hence not for sale. I cant delete the thread.
On another note i had the tests done today. Leakdown test all cylinders 100% no leakage.
Compression test
Cyl 1. 160psi
Cyl 2. 150 psi
Cyl 3. 155 psi
Cyl 4. 150 psi
Cyl 5. 150 psi
Cyl 6. 150 psi
Ocha im not sure what stock psi is supposed to be and neither did my technician. Any info would be appreciated. Oh and does anybody know what bmw uses for stock spark plugs. I assumed bosch but the plugs i have are ngc.
compression numbers are solid, but there is no such thing as 100% no leakdown, so either the person that did it lied to you or doesn't know what they are doing (leakdowns actually pretty complicated)
Originally Posted by Ron Stygar View Post
min. bar 11 - 12
psi 159.5 - 174
While that is BMW spec, you can't use an absolute value comparison for compression tests, only thing you can do is compare between cylinders for variance.
      11-28-2010, 04:44 PM   #113
just2talented
just2talented's Avatar
Drives: Alpine ///M roadster
Ocha. What exactly does a leakdown test entail. I watched him do it. He removed all coil packs and sparkplugs , he did every cylinder at top dead center and measures them with a pressure meter. The meter read 100% each cylinder
      11-28-2010, 04:46 PM   #114
O-cha
O-cha's Avatar
218
Drives: Mcoupe
All engines have leakdown past the rings to an extent, sounds like the correct process though. The leakdown test measures the amount of air that leaves the cylinder. usually it's at least 5% with most gauge sets.
      11-28-2010, 05:46 PM   #115
just2talented
So the compression numbers are good. U still suggest that i get the test done again?
      11-28-2010, 06:36 PM   #116
O-cha
O-cha's Avatar
218
Drives: Mcoupe
No, usually a compression test will show "bad" and then a leakdown is used to pinpoint. Since your compression is good it's likely you don't have any leaks.
      11-28-2010, 06:40 PM   #117
Ron Stygar
Drives: 2006 Z4 M Coupe
So you can't add the absolute compression?
      11-28-2010, 06:43 PM   #118
just2talented
So then car is fixed? No issues?
      11-28-2010, 06:43 PM   #119
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Is that a joke over calling it "absolute"?
      11-28-2010, 07:27 PM   #120
Ron Stygar
That's what BMW calls it.
      11-28-2010, 07:32 PM   #121
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Then I don't understand your question.
