      04-29-2010, 02:09 AM   #23
Serious
1M advocate
Serious's Avatar
Drives: 2018 S4. 2011 M3. 2012 S1000RR
Originally Posted by O-cha View Post
First, you said destroying the motor, that's hardly destroying the motor, I can fix that in an afternoon.
Second the bolts you are speaking of and linked that attach to the camshaft, when they back out, can go nowhere, THOSE do not fall into the engine, they just make noise.
The bolts that can fall into the engine are the bolts that hold the vanos gear to the sprocket. And if these back out the vanos gear loses its preload and rattles like a sonofabitch so not fixing it and letting them back out completely is...
Most of the time when the bolts fall in they don't cause damage anyway, do you know how many BMWs are running around with random bolts in their oil pans? A lot, a whole lot.
Ok ill let everyone who had pieces of vanos unit and cam gear punching holes through valve cover know everything is a-ok.
The whole thing is actually pretty irrelevant, BMW's strategy for dealing with these failures where pieces of cam gear cog, bolts, or any other piece of the vanos unit/valve train becomes loose internally is to just go ahead and replace the entire long block.
It's just depressing to see these failure still occuring (even if the frequency is very low) since all MZ4's should be updated with all the new improved gears and bolts.
2012 BMW S1000RR
2011 BMW M3
      04-29-2010, 09:07 AM   #24
lucid
lucid's Avatar
Drives: E30 M3; Expedition
You'd be surprised to hear that BMW has recently been responding rather differently to engines with major internal issues (as far as I can tell, it is not clear if the OP's problem constitutes a major issue or not yet as I don't know what "a screw fell into the engine" means exactly). Yes, in the past, it appears that they would just hand over you a new engine for anything significant and internal, but that doesn't seem to be as true anymore. I won't get into the details, but let's just say that I've had some first hand experience with dealing with that kind of thing while I owned an E92 M3...
      04-29-2010, 10:23 AM   #25
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Again, that does not constitue a destroyed engine by a long shot.
      04-29-2010, 11:35 AM   #26
Serious
1M advocate
Serious's Avatar
Depends who is defining "destroyed" because for the most part in BMW's eyes (at least in the past) the solution is replacing the entire long block.
Now if I was doing the repair, It would be a whole different thing but all these cars are still under warranty so like I said before it's pretty irrelevant.
2012 BMW S1000RR
2011 BMW M3
      04-29-2010, 03:49 PM   #27
shitbrownMcoupe
shitbrownMcoupe's Avatar
41
Drives: 2006 z4 M coupe
Thanks for the details guys!
They drained out the oil and found no bits and pcs of metal.
They ordered some gaskets and small parts and put it back together, but the engine still won't start.
They're still figuring it out.
The car is a 2006, 11000 KM to date, never really driven really hard, like we're supposed to.
Was planning to keep this car forever and track it when it's book value is close to nil.
What am I gonna do with the brand new in box SS race step headers, race cats, x-pipe and race exhausts that are to arrive in 3 weeks!!!!!
      04-29-2010, 03:51 PM   #28
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
You should be OK, looks like O-cha made the call.
      04-29-2010, 03:56 PM   #29
O-cha
O-cha's Avatar
218
Drives: Mcoupe
No metal doesn't mean much, you can drop a valve and still have no visable metal in the oil.
Is it turning over at all and just not firing?
Hopefully they don't tear apart your engine for an electrical problem like that one guy who had his head taken off because he has an Oring leak oil and the tech decided his headgasket was blown.
      04-29-2010, 04:00 PM   #30
shitbrownMcoupe
41
well it's under warranty until August.
      04-29-2010, 08:31 PM   #31
shitbrownMcoupe
41
I just want my car back... I miss those big shiney wheels and shifting around.. heel toe, revving....
I saw a rusted old 2 door civic today and that made me miss my car! I'm desparate!
This Hyundai courtesy car sucks!
      04-29-2010, 08:46 PM   #32
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
inTgr8r can have the Race exhaust and I'll take care of the rest for ya
      04-30-2010, 12:35 AM   #33
shitbrownMcoupe
41
well, at least I know I'm covered some way or another
      04-30-2010, 03:15 AM   #34
skate0518
Drives: E46-E85-E92-F82
same thing happened to my 05 e46 M3 last yr. But u got lucky, i was going 80 mph on freeway and it stalled. Almost got kill because of this. Anyway, it turned out to be same issue like yours. Stupid Bolts got suck in and kill the engine. They replaced a brand new Engine, but after that the car start having problems. So .... Good Luck <Did they do any Tune b4 ? cuz i got Tune by dealer then shit happened right after> BTW, they should give u a Bimmer to drive around ... i got 335coupe for 1 month.
      04-30-2010, 01:00 PM   #35
shitbrownMcoupe
41
Yeah lucky I was at the drive through. Probably cause I donated 1 dollar to the McDonald's foundation a day earlier... so I got blessed.
Two screws came off, split in half and went into the engine. The timing's off, so the valves pushed and the pistons probably are bent too.... I'm guessing.. the valves are bent and won't seal properly.
I got a 323 as a courtesy... not bad, but no power
You mind telling me what issues came out after you had the engine replaced? So I can prepare for some issues that may rise?
They told me verbally that if the engine get's replaced, they'll give 2 more years warranty on the engine too.
      04-30-2010, 03:21 PM   #36
Serious
1M advocate
Serious's Avatar
What issues? you're getting a brand new engine it won't have any issues.
You have to go through breakin process. 1200mi under 4500rpm and under 110mph or so. then get an oil change at 1200mi.
Yes new engines come with 2 year 50,000mi warranty from install day IIRC.
2012 BMW S1000RR
2011 BMW M3
      05-01-2010, 11:26 AM   #37
shitbrownMcoupe
41
Skate0518 said that there were issues after the engine change.
I don't mind the break in part.
      05-02-2010, 02:17 AM   #38
skate0518
Here is the list of Issues that occurs after Replaced Engine:
1. Cold start the engine makes LOUD squeezing noise.
2. Car stalls when back up slowly. <its SMG @@">
3. Engine shakes a lot compare wiz b4.
4. Can hear the Engine not running smooth like b4.
5. Interior lights dim while aggressive driving.
Above issues made me take more than 15 trips back to
Different dealership. In the end, i gave up and move on
to M Rody
BTW, they only extend warranty on Engine for another year ...
      05-02-2010, 11:30 AM   #39
shitbrownMcoupe
41
thanks for the heads up... I will check them out after it's done
      05-12-2010, 12:06 PM   #40
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
So you got her back.
What's the rest of the story??????
      05-12-2010, 06:04 PM   #41
RBull
Drives: 2007 M Coupe
^yeah, good question?
      05-13-2010, 07:44 AM   #42
shitbrownMcoupe
41
Got her back, some bent valves are replaced.
Engine light is on, and some consistent clicking noise from the engine.
BMW says I have to drive about 1000 KM to work the new parts in and they will do some adjustments after.
Still very powerful car....
      05-13-2010, 07:49 AM   #43
shitbrownMcoupe
41
my SS race system will be here in about 2 weeks... can't wait. hahah
      05-13-2010, 08:32 AM   #44
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Glad to hear that your back on the road.
I would imagine valves will need re-shimmed after a few kms.
