03-04-2017, 07:13 PM | #1 |
Rep 2,199
2006 Z4 e85 getting ASCM internal control-unit fault, 0093D7
hoping I dont have to replace the airbag module, the seatbelt sensors all seem to work ok, Ista-d was not very helpful simply says "replace module, if igniter error fix that first. I dont see any igniter errors. I had good luck with used airbag modules on my E39s, not sure if the E85 can do that though, I did not even have to code the e39 airbag modules.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
