      05-11-2011, 01:35 PM   #23
Rated M
Drives: 2007 IB Z4MC
Hey guys... Just to provide an update... I am 1 track session down and 2500 miles of driving... Still not a single thrown code...
Johaness and I have been in contact for a couple months with his setup.. Apparently he is having a couple codes thrown with the j style bungs and oem wiring (routed out of the valve cover cover, not extended). I am interested in hearing what is causing the issues... So watch his thread for updates..
      05-11-2011, 02:46 PM   #24
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks for the update.
      05-11-2011, 03:27 PM   #25
johanness
Drives: 2008 Z4MC
Getting this worked on as we speak. Will report back. Fingers crossed
      05-11-2011, 10:27 PM   #26
kav
Drives: Z4M
Great thread!
I have done this same modification. The 02 sensors can be "unwrapped" from other wires and harness to give the required length without cutting them. My car has the OEM length sensors behind the secondary cats.
      05-11-2011, 10:35 PM   #27
johanness
Drives: 2008 Z4MC
And no codes whatsoever? Without any aftermarket tune shutting the O2's off? The shop followed the 'unfolding / relocating guide to a T and I still have codes
      05-11-2011, 10:50 PM   #28
kav
Drives: Z4M
I still get periodic codes too despite the tune which reportedly turned off the secondary O2 sensors.
      05-11-2011, 11:47 PM   #29
Rated M
So am I an anomaly here?? Has anyone else successfully accomplished o2 relocation??
      05-12-2011, 05:30 AM   #30
Starscream
Starscream's Avatar
Drives: ///M Roadster + E92 335i 6MT
so far so good for me
Imola Red Roadster
      05-12-2011, 11:23 AM   #31
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
When I do this I will run the euro software. What codes is Johanness throwing? Sometimes its simply an O2 sensor going bad.
Kav- What occasional codes do you get?
      05-12-2011, 12:39 PM   #32
johanness
Drives: 2008 Z4MC
I threw the following codes:
2C7E - Oxygen sensor after Cat trim control
2C93 - Exhaust gas temp sensor plausibility
So I go back to my shop, have them shorten the j-bungs (so that the end of the sensor is as close to Euro-stock as possible) and double/triple check all the wires run. Clear codes.
Drive home - nada.
Drive to get beer @ 6:52pm - CEL!!
I'm officially done with this until someone can point me in the right direction. Running headers w/o software and no codes seems like a lottery shot if you ask me. If anyone has any further ideas, it would be greatly appreciated.
      05-12-2011, 04:57 PM   #33
Rated M
Anyone have experience with these codes ?
Could it be a bad o2??
      05-12-2011, 09:37 PM   #34
johanness
Drives: 2008 Z4MC
Wouldn't think so. Car only has 6500 miles
      05-12-2011, 10:21 PM   #35
kav
Drives: Z4M
I thought it may be the 02 sensors so I replaced both with new ones and still get periodic codes for insufficient secondary cat efficiency. I am going to send my ECU back to ESS to redo the tune.
      05-13-2011, 05:06 PM   #36
Jumbosock
Jumbosock's Avatar
76
I am not familiar with the EGT sensor plausibility fault code. I would only guess that the sensor placed further downstream would get slightly different readings than in their stock location. Enough of a change to trigger this fault code. Perhaps a tune based on the euro software would be better suited to avoid this fault code. Additionally, is anyone with this exhaust mod running ceramic coated headers? The lack of heat loss through the headers might help avoid this fault code. I am just theorizing.
      05-13-2011, 08:38 PM   #37
Rated M
VERY good point!! I did not think of that one... That may very well be your problem there... The secondary cats may not be heating up in a similar manner as stock....
I am 100% OEM no coating...
      05-13-2011, 09:03 PM   #38
johanness
Drives: 2008 Z4MC
I am ceramic coated. You mean because I'm coated, that's the reason I'm throwing them?
I'm more than likely going to go the ESS route and get some Euro-spec tune for my ride.
It makes sense really. I've mimicked Europe 100%, so might as well run their software and then some. What I don't get is how some people are code-free with the same install. I think Jamie (Starscream) is coated, and he's all good. So not sure about that theory. Not sure when this becomes too much of a money-pit of frustration, vs just buying the handheld from ESS and just getting on w/it.
      05-14-2011, 01:06 AM   #39
Jumbosock
Jumbosock's Avatar
76
No, the other way around. I was theorizing that ceramic coated headers would help avoid the EGT code. The fact that you do have ceramic coated headers means that ceramic coated headers don't help much to avoid fault codes.
RATED M was agreeing with me on the Euro software comment. Euro software could possibly cure most fault codes due to this exhaust mod.
As to why some have been successful in avoiding fault codes while others haven't is a good question.
      05-14-2011, 01:38 AM   #40
beta
Drives: 2006 M Roadster
Starscream is euro coded. Not sure if that happened before or after headers.
      05-14-2011, 09:11 AM   #41
Starscream
Starscream's Avatar
No I'm not,
I do have an ESS tune, but it was without the header o2 delete option as I live in NJ and need the car to pass inspection,
Imola Red Roadster
      05-14-2011, 09:54 AM   #42
dorifto88
Drives: 88 Nissan Pathfinder
Stupid question, but the connecting thread, minus m rated, is that kav and johanness both are not flashed?
      05-14-2011, 12:11 PM   #43
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
what does euro coding entail?
      05-14-2011, 05:00 PM   #44
beta
Originally Posted by Starscream View Post
No I'm not,
My bad, sorry for the bad info.
