      10-03-2023, 02:38 PM   #1
wyshyvanuk
Drives: 2008 Z4 MR
QuickJack Balance
Has anyone raised a Z4M on the QuickJack with a "radial shift" to the rear rather than the front? In other words, the car shifts to the rear rather than to the front? The jacking points are roughly the same distance in back of the front tires and in front of the rear tires. With a 50/50 weight distribution, the balance should be fine, no? A shift to the rear would be much easier to accommodate in my garage. Thanks!!
      10-03-2023, 03:01 PM   #2
Piper1
Piper1's Avatar
Drives: E85
That’s the way I lift my non M. Hydraulic lines in front, as car is raised moves rearward.
      10-03-2023, 03:18 PM   #3
wyshyvanuk
Drives: 2008 Z4 MR
Perfect. Thank you, sir!!
      10-03-2023, 05:42 PM   #4
thrak410
Drives: 2004 Z4 Roadster
Thats how I do it too... the only thing about the QuickJack I use is the rear is 100% on the jack points but the fronts are only ~50% on them.
Its still SUPER stable, but I wish it was a perfect fit, ya know.
      10-03-2023, 05:45 PM   #5
wyshyvanuk
Drives: 2008 Z4 MR
Which model are you using? The 5000TL hits both 100%.
      10-04-2023, 08:04 AM   #6
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
I'm using exactly the same technique with 7000slx, works perfectly fine for me in my tiny garage
Powered by
      10-04-2023, 08:28 AM   #7
wyshyvanuk
Drives: 2008 Z4 MR
Thanks, guys!!! I'll flip mine around this week. Andrey, keep your phone on....I'll text you to dial 911 if I need to be extricated ;~).
      10-04-2023, 08:48 PM   #8
thrak410
5000SLX ....
      10-04-2023, 10:44 PM   #9
pungo
pungo's Avatar
IDK, I have the 5000SLX and my jack points sit 100% on the jacks for my E86, not so much on my E39 (but I have a creative solution for that).
There's a 29.5" to 60" spread on the jacks and the Z4 is only 45" at the furthest measurement on the jack points, so it's strange yours is only supported 50% on the front, maybe you have an earlier version of the quickjack?
I checked this diagram prior to purchasing to ensure they would fit properly.
Name:  car fit measurements.JPG
      10-05-2023, 02:46 PM   #10
Z4Kevo
Z4Kevo's Avatar
85
Drives: 2007 M Coupe
rearward shift here too.
2007 BMW Z4M Coupe | Sapphire Black | 19" ZCP Wheels | Michelin PSS - 245/285 | Carbon Leather
Black Corners | UUC Short Shifter | ///M Racing Pedals | OE Strut Brace | LED Accents | PEMP Android
      10-06-2023, 10:19 AM   #11
bosstones
Drives: o_0
Am I the only one that raises forward?!
I have full contact with all 4 side jack pads.
      10-06-2023, 12:21 PM   #12
pungo
pungo's Avatar
No, I go either way, depending what end of the vehicle I'm working on since I place a jack stand under the end of the quickjack where I'm working. I find it stable using it in either direction so don't think it really maters
      10-06-2023, 03:12 PM   #13
Emmrbee
Retired
Emmrbee's Avatar
Drives: 2006 Z4M Roadster
Here’s another option from the Quickjack site if you have a 50/50 weight distribution
      10-07-2023, 09:17 AM   #14
AK72
AK72's Avatar
Powered by
