      02-10-2015, 05:59 PM   #1
DrVolkl
DrVolkl's Avatar
Drives: '08 E93 6spd/ '13 X5M
Rear turn signal issue
My passenger side rear turn signal is out... got the notification on the dash and the speedy blinker when I make right turns.
Ok, simple enough, replaced the bulb except that it didn't fix the problem. Ok, so now what? Is this a common thing?
So turn signal bulb is fine apparently (unless I just happened to have a bad replacement as well)...
E93 6spd
      02-10-2015, 07:26 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Ohm out the bulbs, or hit them with a 9V battery and see if they light.
Then check the fuse.
