03-15-2011, 02:13 PM | #2 |
Rep 143
03-15-2011, 03:47 PM | #4 |
Rep 143
yeah theres not much help around here. and none of the other forums have too many members with z4s. luckily i can relate my m3 problems to this z4 if that makes sense. lol.
03-16-2011, 05:00 PM | #6 | |
instagram 997turbotom
279
Rep 7,376
you're too impatient, and think people here owe you immediate help and information
03-16-2011, 05:07 PM | #8 |
Rep 2,460
I usually never pass up a person let alone a post that needs help, Youre the only person whose said this to me thus far, soooo either Im a pampered post member or your having a bad day cuz youre in Jersey and Jay Wow hasnt been calling you anymore....jking....seriously what gives....can I get help, or words of encouragement in the right direction?
03-16-2011, 05:13 PM | #10 |
Rep 2,460
damn, and damn lol i guess i had a longer day....any how I havent installed the euro's yet the whole thing is stock, my parts are all laid out on the kitchen floor
03-16-2011, 05:20 PM | #12 |
Rep 2,460
Freeze Frame Information:1. DTC for which Freeze Frame was Stored - P1417.2. Fuel System 1 Status - Open Loop.3. Fuel System 2 Status - Open Loop.4. Calculated LOAD Value - 0.00 %.5. Engine Coolant Temp - 59.00 °F.6. Short Term Fuel Trim - Bank 1 - 0.00 %.7. Long Term Fuel Trim - Bank 1 - 3.13 %.8. Short Term Fuel Trim - Bank 2 - 0.00 %.9. Long Term Fuel Trim - Bank 2 - 0.78 %.10. Engine RPM - 0.00 Rpm.11. Vehicle Speed Sensor - 0.00 Mph.12. Ignition Timing Advance #1 Cylinder - 6.00 °.13. Intake Air Temperature - 59.00 °F.14. Air Flow Rate Mass Air Flow Sensor - 0.00 Lb/Min.15. Absolute Throttle Position - 8.24 %.16. Commanded Secondary Air Status - Atmosphere / Off. Monitor Information: 1. MIL - ON.2. Misfire Monitor - Complete.3. Fuel System Monitor - Complete.4. CCM Monitor - Complete.5. Catalyst Monitor - Complete.6. Heated Catalyst Monitor - Not Supported.7. EVAP Monitor - Not Complete.8. Secondary Air System Monitor - Complete.9. O2 Sensor Monitor - Complete.10. O2 Sensor Heater Monitor - Complete.11. EGR Monitor - Not Supported.12. NMHC Monitor - Not Supported.13. Nox Adsorber Monitor - Not Supported.14. Boost Pressure System Monitor - Not Supported.15. Exhaust Gas Sensor Monitor - Not Supported.16. PM Filter Monitor - Not Supported.
this was the read out i got....i copied pasted from my email |
03-16-2011, 05:36 PM | #14 |
The Photographer
76
Rep 628
Where did you fill up??
Could it have been an additive etc? Do you have software for your chip?
John Batte Photography / Flickr / Facebook 2007 ///M Coupe BSM/Black Extended/Loaded | RPi GT Exhaust w/custom gloss black tips | KW V3 | Michelin PSS 245/265 | Pinnacle F1 Tint 35% | ZHP Shift Knob |
03-16-2011, 06:56 PM | #15 |
International Bar Hopper
25
Rep 350
Drives: 2006 Imola Red Z4 M Roadster
I know this sounds like a dumb question! But did you tighten the fuel cap all the way? Did you check fuel filter and pump? The fact that this happened after fueling up leads me to believe it's either fuel cap or bad gas.
Edit: forget the gas cap...that was a dumb question
2006 Imola Red Z4 M, ESS VT2-500 Supercharged, SS V2 step headers, AEM water/meth, Nitto NT555R Drag Radials, ESS VT3 coming
03-16-2011, 07:15 PM | #16 |
Rep 2,460
funny thing when i went to fill gas today I wasnt sure if the wetness around the cap was from gas or water of course my dumbass smelled my glove after i opened the cap so there was no way to tell, control and variable completely obsolete, also my dumbass does not know where the fuel filter is....I will look....
if I manage to fix this with just a tightening of the cap and a filter change i will politely ask that anyone within my area on this post come to my residence at their earliest possible convenience and chivalrously bitch slap me with a napkin and or glove, not in any particular order. ( preferably with an M embroidery, thank you) |
03-16-2011, 07:22 PM | #17 | |
25
Rep 350
03-16-2011, 07:24 PM | #18 | |
279
Rep 7,376
02-19-2023, 08:56 AM | #20 | |
Rep 45
hi,Have you solved it? I have the same problem. |
