      12-13-2016, 01:22 AM   #1
Polarbert
English Member
25
Drives: 2006 Z4M Roadster
LED Bulbs?
Has anyone swapped out the brake lights and indicator lights for LEDs? I have been quite tempted to do but was always put off by the fact that I may get an error light on the dash due to the low voltage they run. I know there are some which can get around that but wondered if they were any good.
      12-13-2016, 11:34 AM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
See this thread for lots of info.
I pulled the trigger on LEDs in post #47, with pics in post #60.
Some tips:
Turn signals and brake lights are monitored, so the LEDs must be "error free", which means they have parallel internal resistors to up the current.
Back-up lights are not monitored.
Try to get red LEDs to replace the brake lights. The whites are 6000K, but the lens is made to light a nice deep red with incandescents of maybe 3500K.
6000K brake lights will come out pink.
Oh, and the LED trunk light mod is a must-do:
http://www.zpost.com/forums/showthread.php?t=772680
kihtay17.50
TRiCC264.50
      12-21-2016, 07:29 PM   #3
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
This looks bitchin'....
https://bimmian.com/Accessories-for-...-Signal-Bulbs/
After much research and WeissLicht's claim of no codes, I purchased and installed the amber LED rear turn signals yesterday.
A five minute process; perfect fitment, incredibly bright (3X), crisp on-off.
The WeissLicht product integrates no code issues, well designed heat sync, lower wattage yet mega-brighter than OEM.
I called Bimmian and asked why there isn't an app for the front turn signals on their site; they said they reality-checked all types, and cannot find one that does not throw codes or does not fit.
The crisp LED on-off and brightness is absolutely awesome.
Racerbruce
      01-23-2017, 01:49 AM   #4
Polarbert
English Member
25
I'm very tempted by these. 100 dollars is a lot for a couple of bulbs though. Would you say they were worth the 100 dollars? I think I'd be more likely to pay that much for the brake light bulbs if they were available.
      01-25-2017, 05:00 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
I thought they recently added Red P21W/1156 brake light bulbs?
I sure can't find them now.
They list amber and white, but as I wrote above, you won't like the white in the brake lights.
I can attest that the turn signals are totally awesome.
      01-27-2017, 01:43 AM   #6
Polarbert
English Member
25
Do you have the brake lights as well? Was wondering if it would look odd to have the led turn signal but not brake lights.
I think I may bite the bullet and get some turn signal bulbs in the near future.
      02-01-2017, 07:41 PM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
I have the white WeissLicht brake light bulbs. Not recommended. Need to be red.
They're 1156/7506/P21W style. Did a Google search.
Philips has some, as do some others, but not sure how bright they would be in our housing.
TRiCC264.50
      03-16-2017, 12:58 PM   #8
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
Do they make LED bulbs for the headlights?
      04-22-2017, 12:11 PM   #9
racerbruce
racerbruce's Avatar
3854
LED Brake Lights?
The OEM brake lights are LED.
Racerbruce
      04-24-2017, 01:42 PM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
Only the third.
      05-11-2017, 09:20 PM   #11
racerbruce
racerbruce's Avatar
3854
Only the third.
06-08 Z's brake lights are incandescent??
Racerbruce
      05-16-2017, 05:49 AM   #12
StickMon
StickMon's Avatar
Drives: 2006 MR
Yeppers.
Tail lights, 3rd brake light, and rear markers are LED. Everything else is incandescent.
TRiCC264.50
