02-27-2017, 04:33 AM | #1 |
Why so serious?
141
Rep 743
Z4 No-Drill License Plate Mount?
Hello!
I've recently purchased the 1M style bumper for my E85 3.0i. On my stock bumper, I had the tow hook license plate mount. On this bumper, here is no tow hook hole for a tow hook mount. Other than drilling a tow hook hole, or drilling holes in general, can someone suggest a no-drill license plate mount that holds steady and sturdy? Thanks in advance. |
03-02-2017, 10:02 PM | #4 | ||
Why so serious?
141
Rep 743
I wonder if the license plate can sit within that giant lower grill...hmmm I should do some measurements and use some zip ties |
03-02-2017, 10:14 PM | #5 |
Rep 12,559
Garage List F15 X5 xDrive35i [8.33]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
I used a low profile frame with rare earth magnets, worked great
SwissArmy140.50 |
03-04-2017, 06:39 AM | #6 |
Why so serious?
141
Rep 743
03-04-2017, 09:57 AM | #7 | |
Rep 2,527
I also recommend the rare earth magnets for a no drill method. |
SwissArmy140.50 |
03-04-2017, 12:25 PM | #8 | |
Rep 12,559
1. Get a metal plate frame like this or make one with L brackets. If you buy the amazon one, spend a few extra bucks to replace the screws with stainless steel ones and rough the frame up with sandpaper and do 2 coats of spray paint to prevent rust. 2. Buy some rare earth magnets for both bumper and plate frame. Trick is to find the biggest diameter that will fit behind the bumper. I got mine from eBay. The ones that go on the plate frame will be smaller. 3. Apply double sided tape on magnets that will go behind bumper. Pop off kidney grills and stick magnets to bumper support bar. 4. Apply smaller magnet to plate frame and then cover the magnet with duct tape to prevent scratches. You should read the write up though, it has good tips on how to drop the magnets for exact placement. I think I chose a strength of 25lbs... magnets stay put at triple digits but not impossible to remove neither. Last edited by 3002 tii; 03-04-2017 at 07:46 PM.. Reason: Video recorded |
SwissArmy140.50 |
03-04-2017, 07:07 PM | #9 | |
Why so serious?
141
Rep 743
Thank you everyone! Thank you 3002 tii and dekaliber! |
03-04-2017, 08:22 PM | #10 |
Rep 12,559
No problem! Also for what it's worth I used a zip tie at one point to tether to lower grills.
SwissArmy140.50 |
03-08-2017, 05:19 PM | #12 |
Why so serious?
141
Rep 743
Thanks angelr. That is what I currently have on my stock bumper. However, as the original post stated, the 1M style bumper for the E85 does not come with a hole for the to hook.
04-04-2017, 10:05 PM | #15 |
Why so serious?
141
Rep 743
