11-17-2011, 07:59 PM | #23 |
Rep 1,663
Let's see some pics guys! Before and after shots are encouraged
11-24-2011, 09:50 PM | #25 |
Rep 38
Wow, great pics dubsesd
I think they look brighter here than they do in real life, but shows off the end result nicely! man your car is nice too. Thanks for the input. You happy with them? Last edited by cooots; 11-24-2011 at 10:01 PM.. |
11-24-2011, 09:56 PM | #26 |
#dubspec
6337
Rep 5,201
Yes. Very happy with the kit. I did however get the replacement R-Dash LED license plate housing lights, that's probably why they are brighter. The kit ones are not very bright
11-26-2011, 01:38 PM | #27 |
Rep 137
for anybody still wanting interior LEDs, bimmian is having its black friday special still going on i believe....should be 10% off and they have 3 different kinds to choose from.
http://www.bimmian.com/ |
11-26-2011, 02:30 PM | #28 |
Rep 1,530
I just ordered a set of these from eBay to install in my 3.0si roadster. Something to do this winter. I can't wait!
@dusesd Thanks for sharing those pics! Looks nice! |
12-14-2011, 02:21 PM | #30 |
Rep 29
www.automationLED.com
in this car there are (2) 12smd godzilla panels for the front map lights and (1) t10 9smd wedge light for the trunk, the license plate and reverse lights will come very soon! |
12-15-2011, 06:31 AM | #31 | |
Rep 1,530
12-15-2011, 04:29 PM | #32 | |
Rep 38
In terms of cost... US$4 delivered. Try it, and if it turns out you don't like them, just throw them out. Can't imagine this happening tho. |
12-19-2011, 10:15 PM | #33 | |
Rep 1,530
EDIT: Never mind. I was able to find them without part #s.
12-19-2011, 10:25 PM | #34 |
Rep 1,530
So, I finally installed my LEDs from the kit suggested above. It was ok. I loved the warm glow but the reading lights were too dim so I'm going to change the LEDs as suggested by other members here. Here are before and after pictures. Sorry if my camera didn't capture enough of the lights. I took the shot with a 35mm f1.8 Nikon lens with a D3100 at ISO 800 and I believe 1/40.
12-19-2011, 11:33 PM | #35 | |
Rep 1,530
I just bought a set of these. It it's got 10 LEDs. It should be bright enough for the trunk.
12-28-2011, 01:23 PM | #37 |
Rep 29
a common mistake when buying LED's is that people assume MORE LED's = BRIGHTER
there are 2 common types of LED's, 5050smd and 1210smd each 5050smd is as bright as 3 1210smd, so a 6smd 5050 festoon bulb is as bright as a 18smd 1210 festoon bulb so for maximum light output, use 5050smd's, check out www.automationLED.com |
12-30-2011, 11:17 PM | #38 |
Rep 862
Very interested in doing this for the Z4M Roady interior lights. I would like to have the lights whiter and a little brighter, but not TOO bright.
Where is the best place to purchase them and what exactly should I buy to just do the cabin lights? |
01-02-2012, 10:03 PM | #39 |
Rep 38
see posts #1 to #37
01-02-2012, 10:07 PM | #40 |
Rep 862
I did, but I am still confused:
"there are 2 common types of LED's, 5050smd and 1210smd each 5050smd is as bright as 3 1210smd, so a 6smd 5050 festoon bulb is as bright as a 18smd 1210 festoon bulb" How the hell am I supposed to know what to buy after that? |
01-02-2012, 11:11 PM | #41 | |
Rep 1,530
Here's the kit I bought from eBay for the Z4. This is what the OP suggested buying. I haven't tried figuring it out yet, but you can probably put together your own set cheaper but it's a bit of a pain in the ass to do. I thought the reading lights were a bit too dim so I tried replacing them with these but it didn't make too much of a difference because you still only have one LED that's really facing downwards. It's not like the inside of the housing is reflective and the other lights on the sides would help. So after ordering some extra LEDs and playing around with them a bit, I'm basically using the same LEDs that came with the kit except for the one in the trunk.
01-03-2012, 07:53 PM | #42 | |
Rep 38
Your probably best to go with the ebay kit I suggested (all the lights are a good brightness, except the roof lights which may be a little dim for some). If it turns out your not happy with the brightness of the roof lights - replace them with some alternatives (going by jjdrivesajazz's post - something with 5050smd LEDs would be your best bet). Again, ebay. At the end of the day, we're not talking big $ here, so don't be afraid to experiment. Hope this helps... |
01-05-2012, 10:09 PM | #43 | |
Rep 29
refer to www.automationLED.com for more pics, check under godzilla and t-rex lights here's a quick comparison to 12smd panels, both have 12 led's, but the left one has 12 5050 LED's, while the right one has 12 1210 LED's |
01-11-2012, 05:44 PM | #44 |
Rep 5
Tags |
led interior light globe bulb |
