      10-08-2015, 05:47 PM   #1
chrisko
chrisko's Avatar
Drives: 2016 M3
Lightbulb Question: Is there a way to turn your tail lights into a decorative light at home?
I have my stock 135 tail lights for my car chilling in my house, and I was thinking it might be cool to buy a wiring harness for it and somehow get it connected to an AC plug so I can turn them on with the flick of a switch.
Has anyone heard of this being done? Or have an idea where to begin?
The idea of turning these into a little lamp or something has been on my mind for awhile now.
Thanks!
2021 M2 Comp | STEK Stealth Wrapped | PSM V2 Trunk Spoiler
2022 X3 M Comp | (SOLD)
2016 M3 | AWE Switchpath Diamond Black 102mm (SOLD)
      10-08-2015, 05:51 PM   #2
tc535i
Drives: 2007 335i, 2001 330i, 1995 M3
you could probably do it with a computer power supply, they convert 110AC into 12vdc just like your car uses, and I'm sure the wattage is well within most power supply's range
      10-08-2015, 07:29 PM   #3
Mr Tonka
is probably out riding.
Mr Tonka's Avatar
Drives: Something Italian
just get a AC to DC 12v converter. Plug it into a switch operated outlet, wire it to the lights.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
http://www.m3post.com/forums/signaturepics/sigpic59612_1.gif
      10-08-2015, 08:25 PM   #4
808@702
8th BMW, 520th Surfboard
808@702's Avatar
496
Drives: My girlfriends crazy!
Location: Las Vegas, Nv. and Honolulu, Hi. and Seattle Wa.
Then buy the rear end of a totaled 135...
      10-10-2015, 12:16 AM   #5
WreckerX5d
Warrant Officer
WreckerX5d's Avatar
Drives: Deezul
Just because the car has a 12v battery doesn't mean the lights are operated by 12v. Figure out what voltage and amps each light bulb requires to run.
I believe I found the circuitry behind the light housing:
https://www.ecstuning.com/BMW-E82-13...ghts/ES207350/
This should give a good understanding on what is required to get this done. It's a simple concept to do but you don't want to take any shortcuts or cheesedick anything when it comes to power.
Deleted, ATM I/C and tuned by B.R.R.
      10-26-2015, 12:54 PM   #6
chrisko
chrisko's Avatar
Drives: 2016 M3
Yeah, it'll take a bit of power research to make sure that's all right. I'm having trouble finding the damn wiring harness though. I have the whole assembly with bulbs already in, but I can't find the wiring online. I came close a few times but pretty much led me to dead ends—kind of just gave up now haha.
Might swing by a dealership and just ask the parts department.
Tags
135, lamps, tail lights
