      06-30-2013, 07:29 PM   #1
Hedward
HammerHead
Hedward's Avatar
Drives: 2007 BMW M Roadster
Fault code assistance
When ordering all of the stuff to complete the inspection II, I picked up a Peake Research Code Reader.
In giving it a spin, it's reporting the following three codes:
2CF9
"Throttle valve potentiometer 1"
2CF6
"Throttle valve potentiometer 1 - plausibility with regard to air mass"
2D09
"Throttle valve"
Would appreciate any comments as to sorting this out.
Otherwise, car running fine in all regards.
      07-01-2013, 12:17 AM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Make a note of it, clear it, and see if it comes back.
These things have a memory like an elephant, and get a lot of one-off errors.
Every time I scan my car with DIS there are about 3 "no longer present" errors from a wide variety of sensors.
I'm guessing it didn't set the Service Engine Soon light, so I wouldn't lose sleep over it.
If it comes back, search for Throttle Position Sensor and start scheming to replace them.
      07-01-2013, 02:21 PM   #3
Hedward
HammerHead
Hedward's Avatar
Thanks, saved me from searching for a solution to an issue that I may not have.
Cleared the fault code and made several start/ stop errands. Checked it upon returning home - no codes as yet.
Appreciate the suggestion.
