      12-13-2019, 11:35 AM   #1
rsutoratosu
Drives: Z4 3.0i
Peeling plastic Q: Center trim
I have several area of plastic trim peeling and since i'm swapping out the center trim, I figure Ill do it all at once..
Using this video for repainting.. I have the beige now and have aluminum trim. Do you guys think I should leave the color the same or redo it with a different color..
Using instructions from here to remove
https://www.zpost.com/forums/showthread.php?t=1230786
-Roranji
      12-13-2019, 01:46 PM   #2
Steeler
Steeler's Avatar
2429
I have painted plastics in the past.
Prep is paramount.
Be sure to thoroughly degrease, apply etching primer and proper plastic(vinyl) paint.
I used PPG products specifically for plastics and the results were very good.
As far as colour goes. My 3.0 came with the beige interior which were promptly stripped and swapped to black.
Be advised you will likely break tabs off during disassembly. The plastics get very brittle from the sun.
      12-13-2019, 01:54 PM   #3
rsutoratosu
Drives: Z4 3.0i
Thanks.. Do you have wood dash trim ? can you post a pic..
i'm wondering how it'll look if I dont do the doors.. lol
Is your seat color black also lmk i can give you address for email photos if you're able to
-Roranji
j03chu56.00
      12-13-2019, 02:02 PM   #4
Steeler
Steeler's Avatar
2429
I replaced the entire interior except the dash with an OEM interior in my Z4
The aluminum trim was powder coated black
Not sure how you would do the door cards.
I had the seats rebolstered and recovered in Alcantara and leather
The interior I painted was in a 67 Mustang.
      12-18-2019, 09:07 AM   #5
rsutoratosu
Drives: Z4 3.0i
I'm just trying to figure out how weird interior will look, beige carpet and if I do the side panels and behind the seats with black or something.. its like half black / half beige.. lol
-Roranji
