      08-23-2019, 07:56 AM   #1
plz4mr
Drives: 2006 Z4 M Roadster
HELP.. Z4M R won't start
Any tips for trouble shooting would be greatly appreciated.
Last night I plugged in a brand new FM/Bluetooth adapter to the lighter socket. Then I went to start the car.
The car wouldnt start, cabin lights flickered. I unplugged the FM/Bluetooth thing and still nothing.
I checked the lighter fuse, the ignition fuse, the immobilizer fuse and several others - all were OK.
The car won't start and I can't think of what to do next.
The lights, door locks and radio work.
The top does not - however I was able to put it down immediately before trying to start the car originally.
Could this be a battery issue?
Or?
Any ideas or past experience is welcome.
      08-23-2019, 12:46 PM   #2
ncnmra
ncnmra's Avatar
Drives: 2006 M Roadster
Can you test the battery voltage? Does it click or do anything when you try to crank it? I had an issue with the BST on my car (https://www.zpost.com/forums/showthread.php?t=1390948).
Internal electrics worked (including softtop motor), but car wouldn't crank or start.
      08-23-2019, 01:41 PM   #3
plz4mr
Hi, no... the car doesn't crank at all. It doesn't click either.
The windows will work but the roof doesn't. Once I turn past accessory though it all seems to die.
The radio does however work.
I have a trickle charger that I'll use on the battery when I get home tonight.
Do I need to disconnect the battery first???
      08-24-2019, 07:52 AM   #4
plz4mr
It's not the battery.
Going to check, and if necessary, recalibrate the RF connection between the key and the ignition next.
      08-24-2019, 08:17 AM   #5
ncnmra
ncnmra's Avatar
Can you see voltage at the positive terminal under the hood? That would confirm proper connection through the main cable and BST.
      08-26-2019, 02:22 PM   #6
apexhittinbull
Drives: E85 M
Quite sure your battery is dead.
The lighter socket is not a key-on or off, it simply stays on all the time having other accessories plugged in would have likely drained the battery out.
