      12-27-2014, 08:43 PM   #1
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
TPMS question
This may be a dumb question, but what happens when you mount a set of wheels that don't have tire pressure monitors installed in the wheels? Will the TPMS light glow forever? Or will it realize the missing monitors and shut the system off?
      12-27-2014, 09:15 PM   #2
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
If you have a model that has the actual transmitters inside the tires, the light will stay on. I believe the TPMS system using sensors started in late '06, early '07. Before that the system detected low pressure by the reduced radius of the low tire causing that wheel to spin faster than the others. There was no in the tire sensor.
Top Down 365
      12-28-2014, 11:19 AM   #3
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
I have a '06 so maybe I don't have the monitors after all. Hallelujah! So any wheel and tire will work. Makes it much easier.
