06-28-2010, 04:40 PM | #45 |
Rep 323
oh another question, sorry for so many questions.
Lets say I get off the highway on to local streets and I'm in 5th gear as I take the exit, The red light is still a bit away but the speed limit is 30mph, can I stay in the high gear just doing 30mph? or do I need to down shift If I don't really need the power? I've just been riding in 5th til I get to the light and dropping it in N once i stop. Is that bad in anyway for the gear? or clutch? |
06-28-2010, 06:44 PM | #46 | |
Rep 1,143
Just don't let the engine speed fall under ~1000 RPM. In 5th gear the engine's going to get pretty bogged down once you start to really slow down. You can feel it. The engine has a natural tendency to idle around 800 or 900 RPM and you don't want the speed of the car to force it below that. It stresses the engine unnecessarily and you might stall. Some people always downshift through the gears as they decelerate but personally I find that it's too much work if I know I'm just going to stop. Plus I'm not good enough to rev-match perfectly every time and it just seems like more opportunity to introduce clutch wear. |
06-28-2010, 07:21 PM | #47 |
Rep 4,320
Drives: '07 Z4 M Coupe
Yeah, coasting to a stop in neutral is fine (not the safest thing - incase you have to accelerate quickly to avoid an accident), but don't let the engine bog down. Basically make sure you keep the RPMs above at least 1k.
06-29-2010, 09:23 AM | #48 |
Rep 4,365
^^WHS. I personally like to downshift to keep in a good RPM range in case I need to perform some sort of evasive manuvers (probably carries over from my motorcycle riding). I usually don't go below 1.5K RPM, coasting in neutral is a good way to go cause it saves gas if that is appealing at all to you (I hope not too much if you are driving an M car!)
06-29-2010, 12:27 PM | #49 |
Rep 238
Staying in gear coming to a stop actually causes leaner fuel ratios if you are coasting to save fuel(vs neutral), also it would reduce brake pad wear. All of this would be minimal savings though.
07-03-2010, 08:32 AM | #50 | |
Rep 146
07-04-2010, 05:59 AM | #51 | |
Rep 56
It used to take deity-like abilities to parallel park with a MT on some of the streets around the UTK campus. |
