      09-08-2019, 10:18 AM   #1
maupineda
Drives: E86 Z4MC
CSL Style Induction Systems Owners: Help!
Hello there folks!
I have bought a nice Z4MC, and it has the CSL Style induction system from karbonius, I have noted two things
1. Brake Feel. for some reason my car brake pedal is very soft and mushy, I wonder if this is in part due to the CSL box affecting vacum
2. Cruis Control Does not work. The car has the alpha-n tune from Epic, and some sensors/connections are just unplugged and let there, I wonder if this is can be part of the issue. I have not looked at the clutch sensor, but since I saw some connectors "modified" I wonder if this is why
Thanks in advance!
      09-08-2019, 01:41 PM   #2
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Soft brake pedal feel - have you tried bleeding (or flushing) the brake fluid system to check for air? Are the brake pads OEM, less aggressive street pads will not match the same strong initial bite.
      09-08-2019, 07:37 PM   #3
maupineda
Drives: E86 Z4MC
The seller changed the pads, so they are new, and I would not know if they bleeded the system. I will start there but seems unlikely.
      09-08-2019, 09:35 PM   #4
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
The CSL box affecting your brake vacuum is doubtful, as my brakes work perfect with the CSL vacuum hose disconnected.
I run epic's tune, my cruize control works fine. (Actually ripping it out today lol)
I'd start with bleeding /replacing oil in the brake system, as said before.
      09-09-2019, 06:47 AM   #5
maupineda
Drives: E86 Z4MC
thanks for the input, what brand of CSL box are you running? I will look at bleeding and at my clutch position sensor.
      09-09-2019, 07:58 AM   #6
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
I had the one from Karbonious (beautiful box that), now running VAC racing box, much, much more raw, Id be bleeding the brakes/clutch at the same time, using some proper fluid.
plug a code reader into the car and see if there are any cruise control specific codes, I did hear of a similar issue with someone across the pond in the UK. might pay to have a sniff around on that /other/ z4 forum for the issue with the cruise control.
Powered by
      10-02-2019, 04:30 PM   #7
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
If there is a clutch stop added behind the clutch pedal then the previous owner might have moved a magnet sensor located near the steering shaft. This magnet needs to be placed perfectly for the clutch sensor to work AND the cruise control to work. Search "clutch stop cruise control" for more info
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
