06-04-2011, 06:07 PM | #1 |
Rep 202
OEM carbon fiber spoiler installation for Z4 MCoupe
Hello everybody,
I wanted to ask a huge favor. I wanted to see if anybody has the instructions on "HOW to install the OEM Carbon Fiber Spoiler"? I got the CF spoiler and the Bettalink but no instructions on how to install it or the points where you need to apply the Bettalink. I did Google and search here for some info but no luck so far. Your help is greatly appreciated! Cheers Panchio
Z4 M coupe with Super Sprint exhaust and X pipe, RPI Scoop, AFE air intake, ESS tune, DINAN 4.10 Limited Slip Differential, OEM CF spoiler.
M3 E92 Coupe with DCT, Akrapovic Evolution exhaust, ESS tune, DINAN 3.62 Limited Slip Differential, OEM CF performance parts. 1M Coupe... Loving it |
06-04-2011, 06:22 PM | #2 |
701
I'd wait for others to answer as well, but my guess is 3M automotive fastening tape.
And congratulations on securing this rather rare piece. |
06-04-2011, 06:42 PM | #3 |
Rep 11,667
I avoided using the Betalink.
If you aren't careful that stuff can create a real mess that is a PITA to clean up. It does provide a more permanent installation, but that also can be a negative. I choose to install with 3M d.sided tape because I want to be able to remove it if necessary w/o damaging the paint. The problem with the 3M install is that you can see the tape under the lip. What I did is run a fine bead of black silicone to hide the 3M and also fill any small gaps, especially at the tips. IMO, it came out perfect. I'll grab a couple of pics tomorrow for you.
06-04-2011, 07:04 PM | #4 | |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
06-04-2011, 07:24 PM | #5 |
Rep 341
Mine's on with 3M tape (the stuff from the auto parts store--not Home Depot) as well...the silicone is brilliant and is now my project for tomorrow. Thanks, InTgr8r!
06-04-2011, 08:33 PM | #6 |
Rep 1,031
I used beta link to install mine. It was messy!!! You really dont need to use a lot of it cause it spreads out nicely.
Just make sure to hold it in one spot while it dries. I think it took 1.5hrs to 2hrs to install and harden enough for me to be okay leaving it. It is easy to clean the beta link junk off your car so don't panic if you make a mess. Before the stuff really hardens its fairly easy to take off with the spatula. Two people make this job easier. If it was just me installing it myself I don't think I could've done it as cleanly. 1.) Clean the area with the supplied cleaner 2.) I applied a thin layer all the way around on the under side of the spoiler. 3.) Make sure it is lined up where you want it and start holding 4.) As hold increases due to drying start to clean off the excess beta link gunk on your car. The spatula works great. Don't worry if it hardens a bit, I was able to get the gunk off almost after 2hrs of work. 5.) Leave it over night, I didn't bother putting anything on it to hold it down over night. It was pretty much permanent when I left it 6.) The ends will stick up a little bit, can use a little more beta link to fill the gap or just leave it. I've left mine for now. Hardly notice it. Hope that helps! |
06-05-2011, 06:55 PM | #7 |
Rep 2,866
OP, do you mind posting a picture or two of the bottom side of the spoiler? I'm considering getting one as well, but not sure how I should mount it. The aftermarket one is hollow on the bottom, which makes it difficult to use the 3M double-sided tape without exposing a gap. Is the OEM piece hollow on the bottom side? Thanks.
06-05-2011, 07:22 PM | #8 | |
Rep 1,351
Drives: in Anger.
Gone (2006 STI, 2008 EVO MR, 1968 Mustang)
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! |
06-05-2011, 07:47 PM | #9 |
Rep 202
Thanks a lot everybody, this info helps quite a bit.
When the dealership told me that the job could take around 3 hrs, I was like "whatever!! I'm doing it myself" but maybe now I understand why... I will post some pictures once the whole thing is completed. Cheers! Panchio
06-05-2011, 07:57 PM | #10 |
Rep 2,866
06-05-2011, 07:58 PM | #11 | |
Rep 2,866
06-05-2011, 08:32 PM | #12 | |
Rep 11,667
It's VERY solid, just get the good 3M stuff.
06-05-2011, 08:41 PM | #13 | |
Rep 202
send some pictures if you can... Thanks man!!!
06-05-2011, 09:07 PM | #14 |
Rep 4,726
the spoiler really doesn't fit that great, I had one and didn't like the fit and eventually removed it. Then again I wasn't patient and installed it with regular 3m, which is pretty thick. 3m has some VERY thin double sided foam tape, but you have to order it, it's not in any stores. I think with the thin stuff I might have left it.
I wouldnt use the betalink for the above reasons
06-06-2011, 12:08 AM | #15 |
Rep 202
here I send some picture of the CF spoiler. Also, the box came with a long black thin sticker and I have no clue what is that for... where do you use it? or what is it's purpose...
06-06-2011, 12:34 AM | #16 |
Rep 2,866
Thanks for the pictures!
