10-01-2015, 11:05 PM | #1 |
Rep 115
Replacing Halo Ring bulbs - LED options?
So one of my halo ring parking lights went out and is throwing a warning light on the dash. I'd really like to replace all of them with LED bulbs for better brightness and longer life. I found these on CarID, but I am skeptical that they will fit.
Has anyone tried this? What would you recommend? |
10-02-2015, 11:56 AM | #3 | |
Rep 531
Surely there is a solution. Most other auto/motorcycle applications just need a resistor to prevent a code from being thrown. The 2008 E92 cars have no problem running LED bulbs for the angel eyes.
E92 M3 - Alpine White - Carbon Roof - 6 SPD - Speed Cloth - No NAV/EDC - Meisterschaft - Signature Forged |
10-02-2015, 03:26 PM | #4 |
Rep 1,991
You can use an LED replacement but it really isn't much brighter from the photos I have seen. It also throws the bulb out code. It is too bad nobody had developed an error free halo replacement but alas they have not. There are also no LED options for the front turn signal bulbs in the hockey sticks...
10-02-2015, 04:21 PM | #5 |
dances with roads
4732
Rep 4,096
Throws a code, really? That piques my electrical interest. It may be happening because LEDs are diodes. Has anyone tried reversing the mounting orientation?
Links to earlier discussions gratefully accepted. |
10-02-2015, 04:35 PM | #6 |
Rep 2,866
LEDs draw much less current than standard light bulb, thus causing the system check to think there's an "open circuit" as in burned light bulb - therefore throwing a light out code. You can code your car to not check for bulb out.
10-03-2015, 06:13 PM | #7 |
Rep 115
How hard would it be to code out the warning light? I'm planning on having a performance tune done on my car later on, so perhaps it could be coded out then?
10-04-2015, 01:18 PM | #8 |
dances with roads
4732
Rep 4,096
Ah, so the warning light is there when the lights are on. I guess you could put a resistor in line to force it draw more current, that way you would keep the bulb check functionality.
10-04-2015, 02:49 PM | #9 | |
Rep 2,547
BTW #1, the resistor would be installed in parallel not in line. BTW #2, the LSZ checks the bulbs when they're not on as well when they're on, so disable both cold and hot checks in the coding. |
10-05-2015, 05:11 PM | #10 | ||
dances with roads
4732
Rep 4,096
Now to figure out how I program an LSZ... ...right after I figure what 'LSZ' stands for. |
10-05-2015, 05:39 PM | #11 | |
636
Rep 3,124
Here's what I have. They have the potential to be brighter, but when you stick them in, the CREEs on the side go a little past the halo ring, so they're not directly lit. No dimmer though, and whiter. Had to code out the bulb check.
10-09-2015, 03:32 PM | #13 | |
dances with roads
4732
Rep 4,096
Seriously, if there is any way for you to recall what you used, I for one would be ecstatic. |
10-09-2015, 03:58 PM | #14 |
salty cowboys fan
6158
Rep 3,407
10-09-2015, 04:17 PM | #15 |
Rep 2,547
Not to say those bulbs don't look nice in this picture, but I'm pretty sure those bulbs would not be very bright in broad daylight. The picture was probably taken with a long exposure in a semi dark area making the bulbs look brighter than they really are.
10-09-2015, 07:49 PM | #16 |
Rep 1,031
10-09-2015, 08:53 PM | #17 |
Ammar
73
Rep 406
When I bought my MRoadster, the very first thing I needed to do was to replace one of the halo bulbs that had gone out. I already knew that I wanted a bright LED option and so I started searching...and searching... And searching. From buying atleast 4 pairs of bulbs online in the past year, the best option is to switch the entire base of the bulb. The Ba9s base that is used for the halo bulb doesnt have enough (good) LED options.
I have a set of LED Ba9s in my headlights but: -they're not bright enough -the blue tint in the headlights for the Halo makes them too blue -for $30 its a waste of money -they dont match the xenons in my car Ive been so busy that I've (maybe) taken the car out about 3 times in the past 4 months. But the moment I find some time ill get around to switching the base of the bulb and putting in a proper LED bulb in there to make it look right. A few months back another member switched the base of the bulb to install a brighter LED bulb and he also had a full DIY for it as well. I would recommend anyone that wants a brighter halo bulb for their car to follow that route. Trust me, its easier that way.
2018 F150 Platinum - Black/Black - Leveled on 34's - DD |
10-12-2015, 02:31 PM | #20 |
636
Rep 3,124
There's a thread around where somebody hacked up the plastic holder and put in BAU15s (1157, 7507, etc.) socket.
Worked out well IIRC. I've been pondering hacking up some spares I have to back the CREE up about 1/4" so the LEDs line up with the halo ring. I've been pondering a lot of things that I'll never get around to.
10-14-2015, 11:52 PM | #21 | |
Rep 107
Not sure if the thread you're referring to is mine but I did this. here is the link: http://www.zpost.com/forums/showthread.php?t=970661 hope it can help someone. |
