      10-04-2015, 10:56 PM   #1
habals
Drives: 2006 Z4 3.0i
2006 Z4 - How to put Aux + USB in Glovebox?
I have a Business CD on 2006 Z4 (E85) model, with no CD changer.
I would like to install AUX and USB(for charging) port in the glovebox so that I can hide the Bluetooth Audio. I currently don't have any AUX installed.
I can see that I can use this to install AUX
http://smile.amazon.com/dp/B000PA00XM
However, I cannot find any instruction how to pull power line to USB port.
What would be the easiest way to do this?
Side question. My cigar jack drains power if something is plugged in, even when the engine is turned off. Is this a normal behavior?
Any comments appreciated.
      10-05-2015, 09:17 AM   #2
Spaceman Spiff
Drives: R8, 996 C2, Z4MR (sold)
You can use a dashcam power adapter and tap into the cigarette lighted lines. Should be an easy project.
This is what you need: http://www.amazon.com/Compact-Hardwi...h+cam+hardwire
