      02-18-2018, 08:05 AM   #1
robert16
Drives: 2007 Z4 SI 36,000
maintenace supplies
Guys I just got my z4. Could you list the best stuff I should be buying.
Oil
filters
rear diff oil, belts
brake fluid
and anything you can think of.
      02-18-2018, 09:42 AM   #2
RGlenn
Drives: 2007 BMW Z4M
First things first! Congrats on the new car! These things are some serious fun .
Can you provide more details on your vehicle? Maint often comes down to age, condition and milage. Post those up and I'm sure the group will have a good deal of helpful ideas. Did the car come with any maint records?
      02-18-2018, 10:44 AM   #3
robert16
Ok I changed my profile.
Just got it home last night, thanks its awesome.
I need to replace the air filter.
The cabin filter is fine.
Wiper fluid fine
I need a bottle of brake fluid, do I need to buy BMW?
Also do I need to buy BMW coolant?
Im gonna use Mobile 1 5w 30
      02-18-2018, 11:52 AM   #4
3798j
3798j's Avatar
11370
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
Brake fluid, I use ATE TYP200.
Oil, I use Castrol Edge euro formula 5w30.
Filters, I use Mahle.
      02-18-2018, 03:46 PM   #5
robert16
I swear I took out 7 quarts of oil, and add 5 1/2 quarts and it says ok.
Any thoughts?
      02-18-2018, 04:11 PM   #6
robert16
What that piece of small flat plastic we need to remove to change the oil? Whats it called, need to get another one. Mine is all bent up.
      02-18-2018, 05:06 PM   #7
3798j
3798j's Avatar
11370
Drives: E86 3.0si
'08 Z4 3.0SI  [8.50]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
Any thoughts?
Capacity is 6.9 quarts. Oil level sensor will only give a correct reading if engine is running and oil is warm...vehicle driven 6.5 miles.
      02-18-2018, 07:19 PM   #8
robert16
So the previous oil change they added too much. Does that hurt anything?
      02-19-2018, 09:40 AM   #9
steffenme1
steffenme1's Avatar
103
Drives: 2007 Z4 MCoupe
Oil drain cover - 51717893279
Mine was missing as well.
      02-19-2018, 07:40 PM   #10
robert16
Found it.
