      11-09-2011, 01:31 AM   #199
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Originally Posted by wyatth View Post
Thanks for the quick reply. I too thought they would fit comfortably based on specs in this thread. Just bizarre that in application, members said they were running -2.5 front camber to fit. Cheers
reference:
http://www.zpost.com/forums/showthre...=e9x+m3+wheels
I'm not sure about the camber required, but more is always better, just in case
      11-20-2011, 03:23 PM   #200
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
19" rims
ok i have been reading this for at least 30 minutes and am more lost than when I started. I am going to go to 19" rims for the DD wheels after the first of the year with width of 8.5 and 9.5. I am running stock suspension and camber. I am leaving it that way for forseeable future. I don't want to run any spacers or roll the fenders. what is the best offsets I need on the 19" rims? OR can 9" fronts work without rubbing? If I go with the 9" fronts I will go with 10" rears
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      11-20-2011, 05:52 PM   #201
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
ET32
ET25
2006 Z4MC - #LL93158
      11-28-2011, 05:42 PM   #202
space80
space80's Avatar
Drives: Z4 M COUPE & 335i msport
hi guys ,
i'm new here I have a z4 m coupe and I must do an order for a set of vmr v701 wheels 18".
the problem is this the front I have decide to fit 8.5 x 18 et 35 and it will fit good without rubbing but i'm not sure for the rear ....
9,5x18 but which et???? vmr advice et 22 but I must fit 255 40 18 tires and when I will fit a bilstein pss10 I think it will rub so vmr give me the option of et 33 and for sure I am inside the fender ......... what do you advise me to choose for the rear et ........
please help me .....
thanks
VINCE CHI SI RIALZA UNA VOLTA IN PIU...!!!!!
      11-28-2011, 06:12 PM   #203
space80
space80's Avatar
I want to present my 2 stars .......... upgrades coming soon....
      11-28-2011, 06:50 PM   #204
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Originally Posted by space80 View Post
hi guys ,
thanks
In my experience and calculations with my car and the GC coilovers with 235/265 Tyres
ET32
ET25
Is a comfortable setup - Much depends on the brand of tyre you choose.
      11-29-2011, 06:08 AM   #205
space80
space80's Avatar
any other advise???? thanks
      12-16-2011, 07:22 PM   #206
TexasZed4MC
Front 19"x8.5" et 30
and
Rear 19"x10" et 22 will these work?
I have a set in mind but this is their limitations
      12-16-2011, 07:41 PM   #207
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
and
Rears may be tight. Tire brand and size needs to be considered.
      12-16-2011, 07:48 PM   #208
TexasZed4MC
Explain tight
      12-17-2011, 07:13 AM   #209
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Explain tight
Using the wheel calculator the rears will EXTEND an extra 21mm from stock.
When I used 12.5mm spacers with 265's I had a minor degree of rub with the OE wheels. Lowered ~ 1".
If you choose the right tire you may be OK.
      12-23-2011, 08:34 AM   #210
pal
pal's Avatar
433
Drives: Z4 M Coupe
I ran 19x10 et25 with 275/30 RE-11s in the back with about 1/2" drop and -1.7° camber. There was just a very very minor rub on the top edge of the tire on high compression highway dips but was fine other than that. This makes me believe that this may ne as far as you can push the rear before you have issues. I used this setup for a year at tracks and driving to/from (as far as 800 miles one way to some tracks) and was happy with the setup.
My local body shop said rolling the lip on the back fender is risky (paint crack) and not advisable (the fender liner sorta rests on it. So they did a very subtle 'pull' on it to get that little bit extra clearance.
Just a word on advice to anyone thinking of rolling the rear fender- be very careful. These fenders dont take rolling well from what multiple reputed shops told me.
      12-23-2011, 12:23 PM   #211
TriAdX
Drives: 1968 Mustang - 07 Z4MC
I am sorry.. I have looked and looked and I just cant find it...
Stock rear M coupe wheels... what is the widest tire I can put on that before it rubs or I sacrifice performance?
(I assume that 40 is the best height?) I currently have 265 40 18 hankook ventus v12's and they seemed ok.. (literally only lasted me 6000 miles... but I also ran them pretty hard and did a smoke out session or 2)
so again,
2007 Z4M Coupe - 2010 Ducati 848 - 1968 Mustang 302
      12-24-2011, 01:32 PM   #212
Beedub
wondering what we all think to the 18" e92 m3 oems would be like...
fronts have et 29 8.5" the rears are a perfect et23 on a 9.5" rim.... id think that these would be fine with lots of front camber, say -2.8 ish??? i think these would look PERFECT!!
      12-24-2011, 01:55 PM   #213
RADRACR
RADRACR's Avatar
For those who are curious:
I'm currently running Rear 19x9.5 ET20 275/30 with .85" drop and there is no rubbing.
Does anyone have experience with a Front 19x8.5 ET32 or more aggressive offset? My next set of wheels is this and I want to know if there are issues with that offset on stock camber.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      12-24-2011, 02:30 PM   #214
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
there is not. im runing 8.5 et35 lowered 2".
      12-24-2011, 02:34 PM   #215
RADRACR
RADRACR's Avatar
So you don't think 3mm more stick-out will be an issue? I currently have 8.5 ET35 and it looks flush with the fender already on the driver's side. For some reason the passenger side looks more inset.
      12-24-2011, 03:40 PM   #216
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
3mm wont make a difference imo especially if you have a mild drop
      12-24-2011, 04:42 PM   #217
Beedub
Im running et 32 upfront and it needed camber to tuck in wheels, im
Running -2.5.... No rub at all and plenty of space, without the camber it would rub for sure.
      12-24-2011, 10:26 PM   #218
RADRACR
RADRACR's Avatar
How wide of a wheel? I have zero rubbing right now with ET35. 3mm is gonna screw me?
      12-26-2011, 04:15 AM   #219
Beedub
19" on a 8.5 width.... Stock suspension..... camber is set @ -2.5... with et32 i can just and i mean just glance the corner of the arch liner where the bumper meets the fenders... its not enough to rub through the liner and it takes every last drop of cornering G force but i can just see the gentle "scuff" of the tyre on the liner..............
when i get my coil overs in ill just add alittle more camber which i want anyway so its not an issue to me....... By the way this is on using every last drop of performance driving...
      12-26-2011, 07:31 AM   #220
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Assuming folks are running 235's on the front with the 8.5 ET32 setup. Do research on tire brand - there is significant differences between brands on the width of the tread shoulders.
