      03-07-2011, 01:34 AM   #23
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Originally Posted by pokeybritches View Post
Higher octane fuel burns more slowly.
Really? That wasn't the case for my tuned MR2 turbo when I ran 100 octane
jk
It was probably cuz I was throttle-happy whenever I pumped 100
The car had a dual-map ROM tune, so at the flip of a switch, I could run 91 OR 100.
      03-07-2011, 01:50 AM   #24
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
As you compress air, it gets hotter. FI requires higher octane by nature, especially when running higher boost levels. However, the point of diminishing returns is still there... it's just slid further up the scale. It all depends on how much the air is being compressed, and how hot it is.
      03-07-2011, 06:22 AM   #25
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
so here is a question that people seem to go back and forth on. okay, so our ecu is an "adapting" one. now while i wouldnt go straight 100 octane, would i see any performance benefit in a 93/ 100 mix? or what about an ESS map that had all the same parameters as my original tune, just switched to 100 octane whenever i'm feeling rich enough to pump 100 oct.?
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      03-07-2011, 11:11 AM   #26
mfanatic325
///M-fanatic
Taiwan
193
I remember a good friend of mine telling me about the current E90/E92 M3's and how from the factory, their ECU's were much more capable compared to the E46 M3, in that just by pumping 100 octane and allowing the ECU to adapt by itself, they were able to get like 8whp increase, or something like that. Someone on their forums actually did a before-and-after dyno to prove this.
With that said, it is known that our ECU's in the E85/E86 M's share similar capabilities as the E90/E92's. Therefore, I personally would not be surprised if our ECU's could squeeze out some hp/tq just by pumping higher octane
And of course, if we do a specific tune for higher octane, we will see much higher gains. How much gain? Who knows such things...every car is different after all
      03-07-2011, 06:49 PM   #27
fr8tdog
International Bar Hopper
fr8tdog's Avatar
25
Drives: 2006 Imola Red Z4 M Roadster
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting. Most normally aspirated engines won't see any benefit to running higher octane and could reduce power.....but mostly it's just a waste of your hard earned money. The Z4 M on the other hand is high compression engine that can suffer from heat soak on the track and the DME will pull timing when it senses knock. If you're running 93 octane or higher the DME will most likely not pull timing. If your just driving around for fun or DD then it's a complete waste of money unless you add a race gas tune. For superchargers and turbos....a completely different ball game. The ESS tune does allow for race gas adaptions and if you get a custom race tune then it will be that much better. I need 100 because my VT2-500(smaller pulley) requires 93 and 91 is all that I can get, so blending 91 with 100 will get my 93 or 94 desirable octane without damaging this awesome motor. I also want 100 for a custom race tune and also some added insurance from not getting a bad batch of gas and then kaboom. With my water/meth and a good mix of 91 and 100 I'm very confident avoiding knock and not loosing power from timing being pulled. Cheers
edit: one other thing.... not all race fuels are created equal. Some are highly oxygenated and produce more power and torque then others. An example would be VP 109(highly oxygenated) unleaded compared to Sunco 100 unleaded. This could be good or bad depending on your use. If your running nitrous or very high boost(turbo) then oxygenated race fuels are NOT good. Nitrous and high boost you should be looking for 110 leaded or something similar(leaded)
2006 Imola Red Z4 M, ESS VT2-500 Supercharged, SS V2 step headers, AEM water/meth, Nitto NT555R Drag Radials, ESS VT3 coming
      03-07-2011, 07:32 PM   #28
fr8tdog
fr8tdog's Avatar
25
Originally Posted by cmark8 View Post
do we actually lose horsepower after a certain amount of octane with our NA engine? I always thought that higher octane is healthier for our engines as it prevents it from knocking. But for fr8tdog, he actually sees a horsepower spike as he's FI and ESS must have a program to run 100 octane. I know for a fact that with VF Engineering + 100oct, my car ran so much smoother and there was a noticeable increase in power compared to 91oct.
On the Z4 M, because of the high compression and sophisticated DME, it is very unlikely you will loose any power from higher octane above 93. I think it would come down to just wasting money on expensive gas. If you are an NA track junkie, you might notice the power holding longer as opposed to timing being pulled during a session on a hot day. I think on the ESS tune you will notice gains up to about 98 octane and after that it becomes a waste of money again unless you get a special race gas tune to fully take advantage of the slow burning fuel. VP109 is a highly oxygenated race gas and this will actually provide more toque than many other unleaded race fuels. With my VT2-500 and VP109 race gas I gained about 30whp on the standard tune.
      03-07-2011, 07:42 PM   #29
The HACK
The HACK's Avatar
1821
Originally Posted by fr8tdog View Post
I expected at least 1 comment like that..that's cool, but I actually did a google and didn't find much, which is the reason I asked. Thanks for the constructive input though. Cheers
Did you actually BOTHERED to click on the link I provided for you? The very first result is a list all stations in California that sells 100 octane fuel.
Last I checked Sacramento is still in California.
And the exact search terms I used were a simple variation to your thread title.
      03-07-2011, 08:19 PM   #30
fr8tdog
fr8tdog's Avatar
25
Actually, it just appeared to be a smart ass reply, kind of like this one^. I was really trying to get some local feedback...as in people on this forum that live in the area. Like... "hey Joe, I know of these stations" Thanks for clarifying, and yes Sacramento is still in CA
      03-07-2011, 08:19 PM   #31
F360C
Drives: E86 S54
Originally Posted by Dubbedown View Post
in nj, the local airport carries it as well as some local performance shops who buy it in the barrels
You can also get it at the Sunoco in Ledgewood at their 100oct Purple Pump. Last time I filled up the turbo with the go juice it was around $8ish per gallon
07 Z4 M Coupe AW/IR
      03-07-2011, 09:51 PM   #32
fr8tdog
fr8tdog's Avatar
25
pokeybritches
Drives: 06 MR, 03 3.0i
This is exactly correct.
