      01-14-2011, 12:43 AM   #1
ryanchua
Z4MC Sapphire Black
Singapore
45
Drives: 570-4SL
Taking longer than usual to crank up.
Hi all,
This is the first time I'm experiencing this on a car.
My car is taking longer than usual to crank up (takes i guess a perceived 1 to 1.5 second longer to crank up). My battery is fine (i have a meter at normal levels) and replaced about 6 months back.
Is there anyone else who's experienced this? What other potential issues might there be? Thanks in advance.
Sorely missed:
Zeta le Z4M Coupe (2008-2012)
BMW.SG - Singapore's Ultimate BMW Enthusiast Community
      01-14-2011, 12:58 AM   #2
Thisisdudewhoru
Thisisdudewhoru's Avatar
Drives: 16 BSM 340i
How often do you start/drive your car. If it's not often, you probably need to turn the car to acc and let the fuel pump prime. I notice that if I don't start it every 3-4 days, it takes a long time to crank and the rpms will dip heavily under startup and then be fine.
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
      01-14-2011, 02:35 AM   #3
ryanchua
Z4MC Sapphire Black
Singapore
45
Drives: 570-4SL
I drive it everyday - just did another search on the forums and found some answers but are similiar to yours. I'll try your method later!
Sorely missed:
      01-14-2011, 07:18 AM   #4
Drives: M2 Comp
This is a fairly common issue.
They may be hard to find, but there are other posts about this.
The general consensus is that it's fuel related.
Some get this when using a particular brand of gas.
      03-04-2011, 11:47 PM   #5
NU arty boy
Fuck it! We'll do it live!!!
Drives: 2008 ///M Coupe, 2008 335i
2008 335i  [8.50]
2008 Z4 M Coupe  [7.50]
I had the same thing happen with my coupe. Dealership ended up replacing the crank position sensor. I hope this helps!
2008 ///M Coupe
2008 335i
      03-06-2011, 12:09 PM   #6
tman53
Drives: 2006 Interlagos M Coupe
I had this problem when I owned my Z3M. The consensus from the forums seemed to be that this was a normal occurence. Not sure it applies to the Z4M, as I have not experienced it with mine. At least not yet.
