      02-07-2016, 05:54 AM   #1
Philly_sweden
Philly_sweden's Avatar
Sweden
580
Drives: BMW M2 2017
  [10.00]
  [9.50]
2017 BMW M2   [7.83]
Steering wheel: Remove spoke covers/plastic?
Hi.
Do you need to remove the airbag to remove the plastic spoke covers?
They need to be changed on a car I'm looking to buy.
Thanks
/Filip
      02-07-2016, 02:41 PM   #2
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Originally Posted by Philly_sweden View Post
Hi.
Thanks
/Filip
Not on a Z4M. Here is a nice write-up in the DIY section:
http://www.zpost.com/forums/showthread.php?t=425662
Salty
      02-08-2016, 01:51 AM   #3
Philly_sweden
Sweden
580
Drives: BMW M2 2017
  [10.00]
  [9.50]
2017 BMW M2   [7.83]
Thank you!
So I dont have to remove the airbag, perfect
      03-05-2016, 10:16 AM   #4
Philly_sweden
Sweden
580
Drives: BMW M2 2017
  [10.00]
  [9.50]
2017 BMW M2   [7.83]
I need the part number for the plastic around the MF-buttons as well but can't fint them?
Anyone know?
http://bmwfans.info/parts-catalog/E8...multifunction/
      03-05-2016, 12:08 PM   #5
Asianoak
Asianoak's Avatar
Drives: '11 E92 M3 & "11 X3
2011 M3  [0.00]
32346785703 should be the part number, looks like it comes as a kit.
Check out realoem.com for more details. Great site for this sort of information.
This is for non M... I have the site saved for my car.
Instagram: @dasianoak
      03-05-2016, 05:08 PM   #6
Philly_sweden
Sweden
580
Drives: BMW M2 2017
  [10.00]
  [9.50]
2017 BMW M2   [7.83]
Thanks but thats not The correct part. Thats The chromeline. I have looked at realoem and bmwfans but cant find it
I need the Plastic parts that The buttons are attached to, not the surroundings
Here
      03-05-2016, 06:33 PM   #7
Steeler
Steeler's Avatar
2429
Not sure you can buy the MF bezels on their own
They are tricky to remove. I did it to have them carbon dipped.
I found this under retro fit on Realoem http://www.realoem.com/bmw/enUS/show...diagId=03_0352
      06-21-2016, 09:42 PM   #8
N55_Mike
N55_Mike's Avatar
Drives: 135i, Z4MC, MK7 GTI
Here you go bud, hope this is what you're looking for.
https://www.ecstuning.com/BMW-Z4-M_C...heels/ES54172/
      06-22-2016, 10:54 AM   #9
Philly_sweden
Sweden
580
Drives: BMW M2 2017
  [10.00]
  [9.50]
2017 BMW M2   [7.83]
Thanks!
I just painted the ones I had Matt black. Much cheaper
