12-24-2016, 01:15 PM | #1 |
Rep 3,004
Bilstein B12 Pro Kit struts/shocks/springs....
For those that have installed:
Fitment? Any issues w/alignment after install? Improved handling? The recent HR failures posted are frightful.
Racerbruce
02-15-2017, 07:55 PM | #2 |
Rep 3,004
My Bilstein B12 Struts/Shocks and Eibach Pro-Kit Springs that lower front 3/4 in and rear 3/8 in arrived....OEM upper/lower strut/shock /spring pads arrived and upper strut OEM guide supports, and OEM front control arm bushings and the upgrade BMW ZHP front control arms.
Install coordinated w/Insp II very soon....updates to follow.
Racerbruce
02-15-2017, 08:28 PM | #3 |
Rep 209
Drives: Z4M roadster
I installed the B12 kit on my last car - a 2011 335is and it was a big improvement over OEM - certainly great value for money. The third best mod after stiffer rear subframe bushings (cheap) and LSD (expensive).
2006 Z4M roadster. Interlagos Blue, black extended leather with carbon trim. Apex EC7 8.5/9.5 x 18 rims, Strong Strut brace, KW V3s with RE rear shock mounts, Vibra Tech and Rogue engine/transmission mounts, Stromung exhaust, CDV delete.
02-15-2017, 08:48 PM | #4 |
Rep 3,004
Awesome - agreed the Bilstein / Eibach Pro-Kit Spring package was only $889 from Turner Motorsport....I purchased all other items noted in my post from Turner as well; looking forward to upgrading the suspension on a 10 model yr old, 62K mile Red Roadster.
Racerbruce
03-08-2017, 05:14 PM | #5 |
Rep 187
I have the B12 kit on my MZ4 coupe, I'm happy with it. Very harsh over sharp bumps but otherwise seems to handle great. Rear sits a bit higher than the front
03-09-2017, 06:20 PM | #6 |
Rep 3,004
Great to hear you Bilstein B12's are great; my B12 upgrade and Insp II scheduled for Tue 14 Mar....will update this thread.
Racerbruce
03-14-2017, 09:08 PM | #8 |
Rep 3,004
Racerbruce
03-15-2017, 06:47 PM | #9 |
Daily driver/Weekend mechanic
Rep 48
Drives: '06 Z4 3.0i Roadster
B12s? That a set of Eibach pro springs and Bilstien B8 Performance Plus shocks right?
03-25-2017, 10:08 AM | #10 |
Rep 3,004
Bilstein B12 Pro-Kit & Eibach Pro-Kit Springs Installed....
Replaced OEM front control arms with BMW ZHP performance control arms, OEM front control arm bushings, all new spring pads, strut support guides and bearings....front lowered 3/4 inch & rear 3/8 inch....4 wheel alignment....performed by Eastside Bavarian - Eric the Tech's acumen, detail, thoroughness and precision is awesome....
First impressions....the visual change is freaking awesome....the seat time reveals it feels like it's on rails....freaking awesome.
Racerbruce
03-25-2017, 10:21 AM | #11 | |
Rep 3,004
Racerbruce
06-17-2017, 08:19 AM | #12 | |
Rep 212
Any possibility to mail me a copy of your order or cart? Any other bushings, parts needed to replace? Thank you for your help.
2019 M2C Sunset Orange/Black (Ohlins/swift coilovers, Ground Control Camber Plates, Dinan Heat exchanger, BM3 ECU tune, CF mirror caps, diffuser and rear spoiler, Vorsteiner V-FF 101 Patina Bronze wheels)
06-17-2017, 09:21 AM | #13 | |
Rep 12,565
07-01-2017, 04:22 PM | #14 |
Rep 48
Thanks Racer.
Same items unbundled. With H&R sways already installed, I started with Eibach springs and Koni Sports. After 20K miles, I swapped onto Bilstein B8s. Frankly, the Konis are far better when high speed cruising. But they aren't as good in town. On the deteriorating streets of Seattle or at low speed, the Konis don't recover quickly. Bilsteins are much more compliant on city streets and are still good at high speed. Whatever you get, if lowering springs, I would suggest you get a pair of 15 mm rear spring pads from Turner to replace the 5 mm ones originally equipped on most non M Z4s. The rear end will sit a bit higher and I think has a better look. I also got the rogue RSMs. So I can drop out the rear shocks without ripping out the trunk liner. - worth the cost, but only if you can deal with the tight space under the tower. |
06-09-2018, 06:44 PM | #15 | |
Rep 12,565
06-16-2018, 09:24 AM | #16 |
Rep 3,004
BMW Z4M Red Roadster Bilstein B12 Lowered Pics
Let me know if this link works....
https://photos.shutterfly.com/folder/20221346720
Racerbruce
06-16-2018, 10:32 AM | #17 | |
Rep 12,565
06-16-2018, 11:49 AM | #18 |
Rep 3,004
Will this work??
Racerbruce
06-16-2018, 12:28 PM | #19 | |
Rep 12,565
How’s the ground clearance? And any details on alignment and what wheel/tire combos you’ve run with these? Ideally would like to be able to track the M few times with a 255 square... Car looks fantastic btw! |
06-16-2018, 12:48 PM | #20 | |
Rep 3,004
Greetings from Seattle....
Racerbruce
06-16-2018, 02:32 PM | #21 |
1821
Rep 5,337
If memory serves, the MZ4 front LCA is already the same part as the E46 ZHP LCA. Part number may be different but the arms are identical.
http://www.realoem.com/bmw/enUS/part...&q=31122343353
06-16-2018, 02:53 PM | #22 | |
Rep 12,565
