06-06-2021, 02:57 PM | #1 |
Rep 73
Drives: 2015 BMW 328i GT, 2007 Z4 3.0i
E85 roof not activating (no lights, no motor noise)
Hey everyone! I just picked up my 2007 e85 Z4 a few days ago, and the roof seems to only work some days. When I got it the roof worked fine, and on the second day it didn't function. The third day the roof was able to open but now we can't close it.
When I press the open roof/close roof button, no lights come on, and I do not hear any roof motor noises. I've checked for blown fuses (12,31,55), and I'm still unsure what the issue is. I don't think it's a micro switch issue because there is no amber light. I've checked the car battery with a voltage meter, scanned the car for codes, and can't diagnose the issue. I think that it must be some electrical issue as I know the motors function properly. Perhaps there's an issue with the buttons relaying the signal to the roof? Does anyone know what I can do? |
06-06-2021, 04:40 PM | #2 |
Rep 847
First, you can operate the top manually (i.e., dropping or lifting by hand) by pulling the release cable in the trunk (red tab). Handy for situations like the top getting stuck open.
Secondly, top issues are plenty and very common with these cars. I'd start by checking the ambient temp sensor (is the temp reading accurate and A/C working?). Next stop is the motor/lines. When the top was operating, did it open and close without hesitation and at the normal speed? |
06-06-2021, 06:46 PM | #3 | ||
Rep 73
06-06-2021, 11:04 PM | #4 |
Rep 847
Yeah the microswitch throws the light, plus it wouldn't be working at all, unless you moved the shelf between the two days. Does the top move up/down manually w/o any issues?
06-07-2021, 09:00 AM | #5 |
Rep 73
Yea there's no issues moving it manually. I was thinking about how the windows don't even roll up/down when I press the button. I think the that maybe there could be an issue with the button wiring but I'm not sure how to take apart the trim to check.
06-07-2021, 11:33 AM | #6 |
Rep 156
Try resetting your windows. Yea, it more than likely isn't this, yet the windows are tied into the roofs operation and a reset is free/quick and worth a shot.
https://z4-forum.com/forum/viewtopic.php?t=196 PS: Originally, your top was stuck down. Now that your moving it manually is it working in either direction (up/down). |
06-07-2021, 12:36 PM | #7 |
Rep 355
This happened to me when I bought my E85.Top worked fine for about 2 weeks, then wouldn't open. The previous owner warned me the motor was on its way out(he was right)
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
06-07-2021, 02:54 PM | #8 | |
Rep 73
06-07-2021, 02:58 PM | #9 |
Rep 73
That's a bummer I just don't think there's an issue with my roof motors because I'm not getting any blinking lights when I press the button... and the roof function flawlessly 2 days ago. It moved at normal speeds and there weren't any weird noises.
06-07-2021, 06:05 PM | #10 |
Rep 156
Here is a go-by for removing the panel with the top up/down buttons.
Your removal starts at about 1:20. I'd hose down the area around these up/down buttons, both front/back with Electrical contact cleaner and hope for the best. However before i did anything I'd look over the micro switch in the trunk. Don't rely on the amber light, it may have failed. Although I never had to deal with a bad micro switch, I've read postings in prior years that there is a way of by-passing this switch. (There might be info on youtube regarding the micro switch) |
06-07-2021, 11:08 PM | #11 | |
Rep 73
06-08-2021, 08:38 PM | #12 | |
Rep 73
06-08-2021, 08:40 PM | #13 |
Rep 73
Link that helped me
06-09-2021, 12:28 PM | #14 |
Rep 156
1st, good for you, and yes you saved some $$$.
Yea, you'd never think the stupid windows could totally screw up the top. Although unusual they can. This is another reason why I never advise adding any new electrical item to one of these cars. |
racerbruce3853.50 |
06-23-2022, 04:20 AM | #15 | |
Rep 7
Hey Spiff, I just picked up a 2004 Z4 a couple of days ago, and it is definitely fixer-upper. I however have all three issues that you stated in the beginning of your second part of your comment. The A/C doesnt blow cold, ambient sensor is all out of whack, and the top doesnt do anything (no light no motor noise) when pressed. Are you saying that a faulty ambient air temp sensor will restrict the top functionality and the a/c??? I was able to find some documentation on the a/c being affected by it, and I have one ordered, but cant find much about the top. I will be VERY pleasantly surprised if this fixes them both. |
06-23-2022, 12:43 PM | #16 |
Rep 156
Hey
1st, I'd get a good code reader on your Z4. Since the car is new to you, running a code reader on it should give you a good start at where to begin. Because your ambient sensor is faulty the car's main computer might believe it's below zero outside. Although, I can't confirm this, I can recall reading a post in the past that either the convertible controller unit or the main computer will stop the convertible top from operating below a certain temp, I think it was 40F. Again, I can't confirm that this is true but, it sort of makes sense as a way of preventing the canvass top from getting damaged. Maybe the AC system is tied into this same safeguard system and will not engage the AC below a certain Temp. A good code reader should give you an idea of what's happening |
06-23-2022, 06:06 PM | #17 | |
Rep 847
06-23-2022, 06:18 PM | #18 | |
Rep 2,704
06-29-2022, 06:18 PM | #19 | |
Rep 7
I have Carly and another high end tester (forgot the name but am going to try it soon) and there are no codes related to top or air conditioning. The only codes I have now are 0027A4 (EWS Interface 3.3 - DME), 002737 (EWS 3.3 tamper protection), and a few instrument cluster codes (also working on an issue where the air bag light is on all the time and blinkers are insanely delayed on the cluster). I have been spending the last couple days doing a cooling system refresh, so I haven't been able to look into these EWS codes and am not very familiar in what they can affect. It does have an aftermarket headunit, which may affect the EWS module? I was also just able to successfully link a new key fob to it. I have also checked the 3 aforementioned fuses and they all seemed fine, even switched them around just to double check. I briefly tried the screenshotted window reset and it didn't do anything but I think I'm going to try that again. Sorry for the barrage of info, but just trying to throw all factors out there because I am honestly just looking for the best path to start diagnosing some of these issues, and if they are linked that would not surprise me. Last edited by mattgc13; 06-29-2022 at 06:23 PM.. |
06-29-2022, 06:29 PM | #20 | |
Rep 7
06-30-2022, 05:32 PM | #21 |
Rep 156
Well, at least you ruled out the temp sensor.
Given your facts try this: It won't cost you any $$ and actually given your facts might be the roof problem. |
