01-16-2017, 09:17 PM | #1 |
Rep 12,559
Garage List F15 X5 xDrive35i [8.33]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
Anyone Replace Parking Brake Shoe?
After 9 years and nearly 80k I think my rear shoes need to be replaced. Tried adjusting the ebrake last year but still doesn't bite unless I really pull the lever to very last 'click'
Just wondering how long others waited till replacing their rear shoes. |
01-16-2017, 10:06 PM | #2 |
Rep 11,665
Did you pull the rotor to check shoes?
Sometimes it's the cable that gets stretched.
01-16-2017, 10:12 PM | #3 |
Rep 12,559
Not yet. That's first thing I was going to do when I throw the track pads back on. But was wondering if 80k was right around time one should have to service the shoes.
01-16-2017, 10:15 PM | #4 |
Rep 2,526
Unless you use your e-brake handle for while driving, I doubt the shoes are warn out. The cable probably needs adjusting. If that doesn't work, as Tgr8r mentioned, pull the rotor and check the condition of the shoes.
01-17-2017, 05:41 PM | #5 |
635
Rep 3,124
I replaced mine when I replaced my rotors at just under 100k miles.
They were working OK at the time. It was one of those "as long as I'm in there, I'm replacing everything" jobs.
01-19-2017, 09:10 PM | #6 |
Rep 18,578
I agree, but what I think the real issue is is rust. The integrated drum is probably rusty. As a maintenance item, it's best to actually drive a few thousand feet with the parking brake engaged to keep the drum and shoes rust free.
