      01-16-2017, 03:41 PM   #1
whoath
Drives: BMW Z4
I have a question for everyone, I have a 2005 BMW Z4 2.5i. About 2 months ago my car started to give problems. When I push the brake the engine would rev up sometimes to the point at a stop I have to put it in park. When I let the brake off it almost dies. The car is an automatic not a stick. Not that I beat my car but when you put the car in drive hit the brake and than hit the gas it does nothing and I mean nothing it`s like the gas pedal is not hooked to anything. I drive this car every day over 100miles I really need to fix it can anyone please point me in the right place...... It is showing codes but from my research some codes could mean a lot of things....... HELP
PS I do all the work on my car so if someone could please help.......
The codes I get are po174,po171,po102,po1447
I cleared all the codes today waiting until tomorrow to see if they come back but the problem with the car is still there.......
I rebuilt vanos over the weekend power better problem still there....
      01-16-2017, 03:55 PM   #2
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
It may sound silly, but are you sure the floor mat isn't somehow hooking or depressing the gas when you hit the brake?
If thats not it...post the codes. That's a start.
      01-16-2017, 04:47 PM   #3
whoath
Drives: BMW Z4
No you don`t understand the engine does not rev at all as I let the brake off it will take off like it`s a switch at a point on the brake pedal to tell the gas pedal to work.
      01-16-2017, 04:54 PM   #4
BartM3
BartM3's Avatar
Netherlands
45
Drives: E93 M3 DCT Individual
Not a mechanic but sounds like a vacuum problem. My guess would be that you have a leak in the air intake or in a vacuum hose somewhere... Sorry I can't be of more help...
      01-16-2017, 05:43 PM   #5
whoath
Drives: BMW Z4
Found 3 fixed all of them problem still there
      01-16-2017, 06:25 PM   #6
mckenna4978
Drives: 07' BMW z4mr-A08
P0174-oxygen sens lean bank 2.
P0171- system 2 lean bank 1
P0102- mass air fliw sensor/low input sensor.
p01447- evap. code.
Check vacuum leak while car is running by spraying carb/throttle body cleaner around throttle body/intake manifold.
      01-18-2017, 07:34 PM   #7
sudoer
Drives: 2004 Z4 3.0i, 2006 X3 3.0i
Possibly a vacuum leak in your brake booster. Try pinching off the vacuum tube to your brake booster.
