View Poll Results: Do you put the car on jack stands when swapping wheels? | |||
Yes | 12 | 42.86% | |
No | 16 | 57.14% | |
Voters: 28. You may not vote on this poll |
02-04-2016, 09:22 AM | #1 |
Rep 904
Using jack stands when you swap wheels?
I've always used jack stands whenever I work on cars in the past, even for simple winter wheel swaps. It's such a pain to get the Z4 onto jack stands though, so now I'm finding myself skipping the stands more and more if I'm not underneath the car. Just curious what everyone else does.
02-04-2016, 10:21 AM | #2 |
Rep 2,782
I don't necessarily put the car on jack stands, but I extend a jack stand up to the frame or lifting point in case the jack fails.
02-04-2016, 10:32 AM | #3 |
Rep 204
My flowchart:
void RaiseCar() { If (I am getting underneath)} I'm even more suspicious if the jack in question is chinese |
02-04-2016, 10:41 AM | #4 | |
Rep 904
If I'm reading that correctly, when you take off the first wheel you put underneath the car, then install the new wheel? |
02-04-2016, 11:04 AM | #5 | |
Rep 204
Now I put the wheel underneath every time, just as insurance. Obviously not as useful in this case, but I'm really gunshy. -gc |
02-04-2016, 11:06 AM | #6 | |
Rep 904
02-04-2016, 04:32 PM | #7 |
636
Rep 3,124
I've gotten really good at popping the car up on 4 jackstands, using a questionable method of jacking it by the pinch rail.
Works, though, so if I have to do anything that requires removing one or more wheels, or working under it, up it goes.
02-04-2016, 06:12 PM | #8 |
Mechanical Engineer
96
Rep 1,025
02-04-2016, 07:10 PM | #9 | |
636
Rep 3,124
Bolt is in a counterbore on the top side. The standard "cup" on the jack is removed leaving about a 3" x 4" flat face and the bolt goes through the hole where the "cup" was bolted on. You don't want to have a groove, because BMW decided that pinch rails are ugly and added some extra to the side skirt to cover them. Before I stick the jack under there, I jamb an 1/8" thick fiber board strip between the edge of the side skirt and the pinch rail, so I don't "pinch off" the edge of the side skirt. It's not as complicated or dangerous as it sounds. The weight is spread across 12" of the rail. I'll try and remember to get some pics tomorrow. P.S. The common spelling of air-ee-uh is a banned word on zpost? WTF
02-05-2016, 08:59 AM | #11 |
Rep 2,782
I found that out a few minutes ago... when I was talking about ____ of expertise. I guess I have none .
02-05-2016, 09:19 AM | #12 | |
Rep 400
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500 |
02-05-2016, 10:01 AM | #13 |
1621
Rep 4,294
Jack stands scare the bloody be-jesus out of me. I have cold sweats of the car flattening me when I am under it, so I no longer temp fate.
Saving up for a lift. |
02-05-2016, 03:27 PM | #14 |
636
Rep 3,124
My pinch rail "jack adapter".
I position it a little aft of the side view mirror, lift one side, put jack stands under the side jack points, set it down on the stands, and then repeat on the other side.
02-05-2016, 04:12 PM | #15 |
Rep 870
Drives: 2006 BMW Z4M Roadster
It looks like a lot of folks jack their car up in their home garage. Are your garage floors completely level or do they have a slight slope?
Salty
02-05-2016, 04:38 PM | #16 |
Rep 2,704
Check out this circus act
Seriously though 4 jack stands is the only way to be safe. You hear of too many mishaps from malfunctioning trolley jacks
02-06-2016, 08:31 PM | #19 | |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
02-06-2016, 08:36 PM | #20 | |
Rep 182
02-06-2016, 11:59 PM | #21 |
636
Rep 3,124
Be careful with the side skirts.
I have some pieces of 1/8" thick fiberboard that I wedge between the pinch rail and the lip on the side skirt, so the pinch rail doesn't pinch it off. After jacking it up about 50 times they're starting to get a little beat up. I have a strip of 1/8" thick 1" wide aluminum. I'm thinking about cutting a couple of 12" long pieces of it and putting them in there permanently. Also, since I have standard "general purpose" jack stands, I cut 4 pieces of 1x2 about 2 inches long that fit nice and snug in the rubber jack points. They convert the jack points from innies to outies.
02-07-2016, 08:15 AM | #22 |
Rep 874
I almost always use a lift even when I change tires, but if I do change tires without the lift I never use jack stands. If I get under the car I always do, sometimes even if it's on the lift and I will be under there for a long period of time. You can never be too safe.
