02-05-2016, 01:40 AM | #1 |
Rep 130
Turn off airbag passengers side
Hey guys i am going to be a father in march?
But how do i turn of the airbag on the passengers side ? In germany they have a button built in for the M coupe but mine doesn't have that button It is a M Coupe from 2007 |
02-05-2016, 04:27 AM | #2 |
701
Rep 7,850
Open passenger door all the way. Follow the a pilar down to the side of the dash. There's a switch you use the car key to turn on/off.
Remember to turn it back on for adults and vice versa! |
02-06-2016, 04:06 AM | #3 |
Rep 130
I don't think i have that button can you please send me a pic of it
[IMG]http://i1028.photobucket.com/albums/...psfwa7dlst.jpg[/IMG] |
02-06-2016, 11:46 PM | #4 | |
636
Rep 3,124
02-07-2016, 12:33 PM | #5 |
Rep 4,057
Are you in Eutope? I think all North American spec cars can turn off the passenger airbag with this switch But I don't know about cars built for other countries.
02-07-2016, 02:14 PM | #6 |
Rep 453
Drives: 2007 Z4M Coupe
I believe in North America the Passenger airbag should turn off on its own. There should be a occupant weight sensor in the seat that tells the bag to disable if the occupant doesn't meet a minimum weight. There's should also be an indicator light somewhere in the IP or console that indicates the bag is off. No sure exactly where it is at on the Z4's. In Europe they use the key switch on the side of the IP.
02-07-2016, 03:50 PM | #7 |
Rep 453
02-07-2016, 05:19 PM | #8 |
Rep 4,057
The indicator light is on the opposite side of the much maligned sport button ahead of the shifter.
The airbag switch ensures the airbag won't inflate when the passenger is someone who could be injured by it - such as a very small child in a car seat. |
02-08-2016, 02:31 AM | #9 |
Down Under!!
1621
Rep 4,294
yeah euro models have that switch, so its US cars that don't?
Voss, your driving a US car in holland? wth?
Powered by |
02-08-2016, 07:16 AM | #10 |
Rep 4,057
Hey Vanne!
My car is a US-spec car and it does have the switch to turn off the airbag, and the indicator light on the center console just to the right of the shifter. I presume Canadian cars are identical in that respect.
Huz-Z
02-08-2016, 01:35 PM | #13 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
I have a US model and have the airbag switch.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
02-08-2016, 01:58 PM | #14 |
Rep 130
Memento has a switch on the right of the shifter and that's a german car
Mine is a original dutch car but nothing to turn of the airbag What is the best solution ? |
02-08-2016, 04:37 PM | #15 |
701
Rep 7,850
Been away, sorry. As others noted you have the place where the switch would be. I believe at least the ///M model has both the mat and the switch in the US. I have to manually turn of the air bag when I have this guy with me (he weighs 50 lbs) vs. the Jack Russell (17 lbs) yet I don't want the airbag on with him in the car.
But the sensor mat ought to do the trick if it's there. You can use the light and some test weight to check. See whether a test weight of under 40 lbs (or whatever you expect baby plus car seat to weigh) triggers the airbag system on or off and check via the airbag light. Another idea: check the owner's manual. If you no longer have it, you should be able to download it for a specific region/country from the BMW site. That should provide you with the "official" solution. It's available at the BMW USA site - I'd expect you could find the main Z4 as well as M supplement online for the Netherlands (otherwise perhaps a call to the regional office, not dealer might help). Before anyone worries about my dog riding with me in the car, he's secured via his harness and belt system when he's out with me. He's actually quite a good driving safety system --he can spot a dangerous driver around us even before that person makes a stupid move. As a herding dog it's his job to spot a cow or sheep that's going to be a problem and do something crazy or otherwise needs to be reigned back in. He can spot minute movement and actions that indicate a dangerous car/driver. Last guy he stared and growled at cut into my lane 5 seconds later, then raced ahead. My dog kept an eye on him until he was out of sight. When I caught up with the driver my dog alerted to about five minutes later that guy had put another car and himself into the center guard rail. Last edited by Finnegan; 02-08-2016 at 05:15 PM.. |
02-18-2016, 05:00 AM | #17 | |
Rep 130
But stil no solution |
02-18-2016, 07:10 AM | #18 |
Rep 870
Drives: 2006 BMW Z4M Roadster
There are probably more Euro drivers on Z4-Forum that might be able to shed more light on the switch situation. Since other Euro models have the switch, I wonder if it is a mistake -- the factory forgot to install the switch? If you press on the center of the small circular indention on the side of the dash, does it give? Does it feel like there is a hole under there with only a thin covering of the dash material? I don't know how they install that switch when the cars were being assembled, but wondered if all are like that at one point during assembly, and an installer punches out the thin dash material over that area and installs a switch. Pure speculation. Probably wrong. ;-)
Salty
02-18-2016, 09:12 AM | #19 |
Rep 2,138
Drives: Me
Has anyone actually read the owners manual???? I have and it does tell you how to do this.
02-18-2016, 03:13 PM | #20 | |
Rep 130
And i don't have a switch |
02-18-2016, 03:19 PM | #21 | |
Rep 130
There is also a light on the right of the shifter I don't have that light I think it was a option the switch and the warning light |
