05-22-2012, 11:02 AM | #1 |
Rep 12,565
Random question and P/N Request (Wire Running Behind Rear Bumper)
Does anyone know what the p/n is for this wire (circled) that feeds into left license plate light? Also I’m assuming this wire begins/ends where the red square is, ie it’s not one giant harness? I managed to mess up with one of the clips for the wire a while back and used electric tape as a fix but now the left bulb randomly goes on / off. It seems easier to just replace the wire if possible.
(Thanks to EAS for the picture) Last edited by 3002 tii; 05-22-2012 at 11:18 AM.. |
05-22-2012, 11:16 AM | #2 |
Not a New Member
94
Rep 925
if it's the connector at the lamp, replacement parts are available...
61.13.8.365.340 Qty 1 (connector) 61.13.0.005.199 Qty 2 (wire length w/ pin) you'll also need some butt-end connectors to splice these into the harness. if it's the whole harness you're looking for, i believe it is... 61.12.9.119.186 Qty 1
05-22-2012, 11:18 AM | #3 | |
Rep 12,565
FYI this is the clip that got fudged |
05-23-2012, 08:31 PM | #4 | |
Rep 932
http://www.zpost.com/forums/showthread.php?t=681276 |
05-24-2012, 08:18 AM | #5 | |
Rep 12,565
So going off the pictures from the German DIY, just take apart stock plug, get to the 2 wires. Install new plug and new plate light? |
05-24-2012, 10:53 AM | #6 | ||
Rep 932
05-24-2012, 11:13 AM | #7 |
Rep 12,565
Put my order through, $30 or so... not bad!
05-24-2012, 07:02 PM | #8 |
Rep 932
The brightness on these lights are just right for me. OEM fitment and cheaper than aftermarket. Let me know how it works for you.
06-09-2012, 06:09 PM | #9 |
Rep 12,565
Bump ordered the oem led's, looks great and perfect fitment!
