06-12-2012, 08:19 PM | #1 |
Rep 5
Potential 2003 Z4 purchase - top won't function
Hi all,
I'm looking at a 2003 Z4 2.5 5-speed with 99,000 miles. It's in very good condition, but the seller states that the top won't lower or raise due to an electronic control failure of some sort. (the top appears to be in very good overall condition) He states that the motor does work; it's the electronic control/switch that isn't working. It's currently priced at $10,500 USD. How much should I be concerned about the top not functioning? If the problem is as described, how much could I expect to get it fixed? How easy/difficult is it to lower and raise manually? Many thanks in advance for your help. former 325 and 633csi owner |
06-12-2012, 09:31 PM | #2 |
Rep 26
I just bought a 2003 Z4 2.5i that had the top repaired with the same problem and it cost 3K. The whole top has to be removed to repair the motor, actuators and switches. Be careful and good luck!
06-13-2012, 08:05 AM | #4 |
Rep 1,907
I have the same issue on mine. The motor itself is about $300 labor is a bitch though. I was quoted $900 total from a local indy shop.
You can manually lower and raise the top (at least in my 2006). There is a release valve in the trunk that bypasses the motor so you can lift it up and down freely. That is what I have been doing. It's not that bad especially since I either have it up all day or down all day. |
