      06-13-2018, 10:39 AM   #1
Nordgeist
Nordgeist's Avatar
33
Drives: 2006 BMW Z4M Roadster
2006 BMW Z4M  [7.00]
Engine Died
Anyone else have this problem? I was driving to work this morning in my Z4M, engine was still cold, and as I was about to pull onto the freeway my engine cut out. Obviously the power steering was gone so I pulled over and turned it off, then restarted and everything was fine.
This is the third time it's happened, seems to happen every 4-5 months, with no other issues.
Mechanic suggested it's the crankshaft sensor, he's going to look at it later, but does anyone have any experience with this?
      06-13-2018, 10:10 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
If it was angry enough at a sensor reading to shut the engine down cold, it should definitely have stored a code.
If there's no code stored, then I would suspect some sort of intermittent electrical connection.
