04-14-2016, 10:07 AM | #1 |
Rep 870
Drives: 2006 BMW Z4M Roadster
I've got a screw loose
I've got a screw loose. Have any of you ever experienced a loose screw on the seatbelt guide on an M seat? I've gone one that just spins -- can't remove it or tighten it. I'm guessing whatever it screws into inside the plastic seat back frame is loose. Am I going to have to take the seat apart to fix this?
Salty
04-14-2016, 05:24 PM | #2 |
Rep 11,667
I'm not sure there's anything behind it .
I could be wrong but I think it just screws into plastic.
04-14-2016, 05:50 PM | #3 |
Rep 2,704
Don' t we all
It may different on an M but my nonM seat belt guide inner structure is metal. Trying putting pressure behind the guide with a putty knife and see if the screw will back out. If it does try a slightly bigger screw or put a dab of RTV on the screw and wind it back in. I don't think you want to take the seat apart unless you have a lot of time to waste and possibly not be happy with the results once put back together.
