      12-01-2008, 01:32 PM   #1
wyu177
Drives: 2019 m240i
Linea Corse Lamans
Thinking about running the Linea Corse Lamans setup on my 08 M coupe, On their website they offer different offset choices:
19x8.5 ET30
19x10 ET 37
http://www.wheeldude.com/catalog/pro...oducts_id=5475
and
19x8.5 ET30
19x10 ET22
http://www.wheeldude.com/catalog/pro...oducts_id=5646
Can someone tell me which would be a better fit for my stock suspension'd M coupe?
thanks
      12-01-2008, 04:46 PM   #2
jragan
Imola Lover
jragan's Avatar
Drives: 2007 Imola Red M Coupe
Here are some comparisons between stock and the new setup. I made some educated guesses as to the tires involved. Note that the front tire size I used (255/35) on the new rims is a touch taller (0.3%) than stock although negligible...and the new rear tire height (295/30) is identical to stock. (I have no idea if these tire sizes are even available)
Front:
http://www.bigcustomwheels.com/rt_sp...Corse%20Lamans
Rear 37 Offset:
http://www.bigcustomwheels.com/rt_sp...20Rear%20%2037
Rear 22 Offset:
http://www.bigcustomwheels.com/rt_sp...20Rear%20%2022
His: RIP-"Ruby" E86 ///M Coupe: Pics Track Pics Short Vids Long Vids
Hers: 997-1 C4S: Pics
      12-01-2008, 05:51 PM   #3
Z4HN
Drives: '05 Z4 3.0i, '08 M3
You can afford an M-coupe and you can't afford authentic BBS wheels?
You realize those replica's weigh 35lbs right? If you don't know what this means do a search on unsprung weight.
Seriously I don't get all those who put cheap replicas on their $40k~50k cars. Just get the real thing and don't get it at all.
      12-01-2008, 06:19 PM   #4
wyu177
Drives: 2019 m240i
jragan, thanks for looking up that info on the website
Z4HN, thanks for your input. From what I understand these rims are ~ 24 lbs front & ~ 27.5 rear VS ~21 lbs front & ~24 on the BBS LM. Stock rims weight in at ~ 24.6 lbs front & ~ 25.7 lbs rear. So it isn't as big a difference you make it out to be. If you have information showing otherwise, it would be greatly appreciated.
      12-01-2008, 07:40 PM   #5
Z4HN
You're wrong. BBS LM's weigh 24~25lbs. Those fakes weigh 30~35lbs.
      12-02-2008, 10:14 AM   #6
Spartiati
Spartiati's Avatar
Drives: 2008 Z4 M Roadster
So here we go again, anytime someone posts questions concerning reps of any kind someone has to throw the "if you can afford a BMW then..." BS out there. His question was what offset would look best, not your opinion on why BMW owners should by definition be inclined to spend upwards of 10% of their car value on wheels and tires just because they can afford to.
      12-02-2008, 10:17 AM   #7
Spartiati
Spartiati's Avatar
You may be right, but for your post to be helpful can you point us to where this data may be found?
      12-02-2008, 11:44 AM   #8
wyu177
Drives: 2019 m240i
Your right, the weights I posted were for the BBS LM 18" wheels, tirerack states 24~25 for 19" BBS LM's. As for the replica weight, this is where I got my info:
http://www.e90post.com/forums/showpo...2&postcount=11 I also found similar information on a different forum, but i'm not sure what the rules are on posting links to other boards, so I won't post.
