06-26-2012, 06:39 PM | #1 |
Rep 82
Z4 coupe, How is this part removed/installed?
Got car back from dealer and panel no longer sits flush. Have a call into dealer, but would like to avoid having to go back if panel can easily be popped off, re-aligned and then pushed back into place.
How is this thing removed? Is it screwed down? Something else have to be removed first? Panel sits on top of rear bulk head right in the center. See Picture. |
06-26-2012, 06:59 PM | #2 |
Rep 29
Hi
If that is the top panel between seats and above center compartment it is held down with four metal spring clips and it does just pop off. I put my Dice module under it for easy access. |
06-26-2012, 07:37 PM | #3 | |
Rep 82
Stupid question: how do you remove a panel held by spring clips? Just yank on it really hard? |
06-27-2012, 09:09 AM | #4 |
Bad Lieutenant
233
Rep 3,517
It removed from the rear, be careful, that is some shitty plastic. The front has a couple of levers that slice into slots in the front side. I had to remove this and place some anti-squeak tape (3M) underneath, it was a squeak magnet.
07-03-2012, 08:28 PM | #5 | |
Rep 82
Wish I knew what the panel looked like underneath so I could pull on the right spots. |
07-04-2012, 10:05 AM | #6 | |
Bad Lieutenant
233
Rep 3,517
#16 in this pic doesn't really detail the underneath and the clips, but #17 is what the clip looks like.
Tags |
panel, rear bulk head |
