      07-29-2007, 11:52 PM   #1
Waldorf
Black Opps field agent
Waldorf's Avatar
Drives: 135i M
Z4 M front bumper vents
i have a question for those who have removed the front bumper cover.
my passenger-side vent (the mate black part) is loose. i have checked the clips in the wheel well liner and they are intact. that tells me that there are other tabs or clips arount the front opening that could be broken.
could anyone tell me a little more about them?
:rocks: Montreal to Vermont OktoberFast cruise. :rocks:
http://www.e90post.com/forums/showthread.php?t=79557
      07-30-2007, 08:28 AM   #2
F360C
Drives: E86 S54
There are two clips on top of the brake duct that clip into a bracket that is located above the brake duct. This is what holds the brake duct in place. The bracket is black and is shaped like an "L"
07 Z4 M Coupe AW/IR
      07-30-2007, 08:34 AM   #3
Waldorf
Waldorf's Avatar
Drives: 135i M
so those would be part of the bumper cover. holding the front of the mate black plastic trim. right?
      07-30-2007, 09:14 AM   #4
F360C
Drives: E86 S54
No its actually a black painted metal bracket that I believe bolts on to the front clip of the car.
07 Z4 M Coupe AW/IR
      07-30-2007, 09:17 AM   #5
F360C
Drives: E86 S54
The bracket I speak about is part number "19"
07 Z4 M Coupe AW/IR
      07-30-2007, 11:53 AM   #6
mister_roger
mister_roger's Avatar
13
Drives: 2003 Maldives Blue 2.5i
Ooooh, this is actually something I would like to know as well. I'm doing an ///M bumper conversion soon, and will need to purchase these brake ducts and brackets, so I need to know how they attach. I saw the realoem diagram, but it wasn't exactly clear, but if the bracket is something that just attaches to the front clip, then that should be pretty straightforward. I guess in my case it's just a matter of hoping that holes are already present for mounthing (since my car is a non-///M)
But if anyone out there has a real picture of the actual brake ducts with the front bumper removed, that would be most helpful indeed!
My apologies in advance for hi-jacking this thread
      07-30-2007, 12:03 PM   #7
Waldorf
Waldorf's Avatar
Drives: 135i M
BTW, they are not brake ducts. They are to apply downforce. They force the air through a small hole upwards onto the tire.
The only way to have ducts going to the brakes would be to catch the air flow from the central vent.
      07-30-2007, 12:03 PM   #8
Waldorf
Waldorf's Avatar
Drives: 135i M
so it looks like my bracket #19 may be broken. damn it
thanks for reminding me about REALOEM.com, it really is great help.
      07-30-2007, 12:28 PM   #9
F360C
Drives: E86 S54
More than likely it not the bracket that is broken but the clips on top of the brake duct. I have a new brake duct on order right now because mine are broken from a small incident at the track
07 Z4 M Coupe AW/IR
      07-30-2007, 12:30 PM   #10
Waldorf
Waldorf's Avatar
Drives: 135i M
how much was the duct?
      07-30-2007, 07:43 PM   #11
F360C
Drives: E86 S54
$30 something.... i ordered it from real oem but its been on back order for a couple weeks now
07 Z4 M Coupe AW/IR
      07-31-2007, 12:04 AM   #12
Waldorf
Waldorf's Avatar
Drives: 135i M
thanks
