      05-29-2014, 05:05 PM   #1
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
So, there's a guy on FB who installed N52 headers built for the e90/92. Here's the dyno without headers, with headers and with headers with tune. 283hp.
      06-05-2014, 10:32 AM   #2
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Was it a straight install or was there some fabrication to get them to work?
      06-05-2014, 03:07 PM   #3
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
The guy said it took some fabrication.
      06-05-2014, 11:10 PM   #4
3002 tii
3002 tii's Avatar
2283
Peak hp on dyne doesn't mean much since every dyno baseline will vary. The delta is what's most important and 22hp is pretty darn good.
There's a guy on e90post (sn: TSM330i) that drives a Z4 3.0si race car and he has Supersprint headers -- those are the only direct fit ones I know of. I have thought about SS headers for a while but emissions is too much of a b*tch to deal with.
Follow for latest mods
      07-30-2014, 09:08 PM   #5
jmilt13
jmilt13's Avatar
19
Drives: 3.0si Coupe
any pictures or links?
      08-01-2014, 06:28 PM   #6
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
It was some guy in europe. He didn't provide pictures of his headers. If you have the stomach for it, you can try to joint the Z4 owners group on FB and try to contact the guy for more info. This is probably hundreds of posts ago.
      08-02-2014, 09:54 AM   #7
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
I don't trust one-off dynos, because so many put in their own correction factors to read whatever they'd like. Wheel horsepower, on a Dynojet, with SAE correction factor, is my preferred standard. That's not to say other dynamometers aren’t as accurate, but a Dynojet is common and results are replicable. Otherwise, you get a bunch of guys claiming, “Well x dyno reads lower than a Dynojet, so on a Dynojet I would have 50 more horsepower…”
I agree that the delta is what matters. It’s about % difference, not just the actual horsepower numbers. Throwing in a different correction factor can inflate the numbers and therefore the horsepower gain. And the graphs should show multiple runs with each setup. There was ~8 horsepower difference between my first and third (worst and best) runs on my non-M.
      08-04-2014, 07:41 PM   #8
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Mre info on this?
      08-11-2014, 01:05 PM   #9
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
I wish I had more info, but this is the best info we have. The guy used a header from a N52 made for a 328. He had to have it customized so it would fit his Z. SuperSprint makes one for the Z that is a direct fit.
      08-11-2014, 01:20 PM   #10
3002 tii
3002 tii's Avatar
2283
Direct fit to manifold, NOT to section 1. You have to buy their high flow (secondary) cats if you want a pnp system or have an exhaust shop build you custom piping to get everything to mate up. Btw those 2ndary cats from Supersprint are even MORE expensive than the headers lol.
