04-10-2018, 10:54 PM | #1 |
Rep 151
Differential Fitment question! Help!
Hey guys. Found this 3.91 diff on eBay. Just wanted some sort of confirmation that it would for sure work on my 2.5i z4 auto before I purchase it. Please advise. Thank you!
https://rover.ebay.com/rover/0/0/0?m...2F273149497429 |
04-11-2018, 08:22 AM | #2 | |
Rep 2,705
http://www.bokchoys.com/differential/GearRatios.htm Edit: I tried 3.73:1 and found it way too low. First gear was useless.
04-11-2018, 08:27 AM | #3 | ||
Rep 151
04-11-2018, 08:46 AM | #4 |
Rep 2,705
Well according to the reference site the ebay diff won't fit
04-11-2018, 08:50 AM | #5 |
Rep 151
Dang it. I know I have a 3.64 diff but would like to upgrade it to 3.91 or at least 3.73. What car would share the right diff with my 2.5i? I'm not seeing any E46's that would have that
04-11-2018, 08:58 AM | #6 |
#buildnotbought
10877
Rep 4,895
The ebay diff isnt listed on bockchoys.
The diff is located in germany and came of a car that was never sold in the US. The listed partnumber in the ebay ad is not correct, at least I cant find it in the ETK.
04-11-2018, 09:24 AM | #7 |
Rep 151
I just read that E39 differentials can be shared with E85. Could somebody confirm this. And if it does, would it be better to use a diff from an auto? Or could I use a manual
04-11-2018, 10:28 AM | #8 |
Rep 2,705
I got my 3.73 from a 2008 SMG Z4
04-11-2018, 12:19 PM | #9 |
#buildnotbought
10877
Rep 4,895
They cant, the housing is not compatible.
Maybe some internals can be swapped over from certain types, but that requires a special skillset.
04-11-2018, 02:00 PM | #11 |
Rep 2,705
From Bokchoy
04-11-2018, 02:05 PM | #12 |
Rep 151
04-11-2018, 02:52 PM | #13 |
Rep 2,705
Actually it looks like only the 2.5 X3 has the 3.91 that should fit your E85
http://www.bokchoys.com/differential/GearRatios_E46.htm
04-11-2018, 03:05 PM | #14 | |
Rep 151
04-11-2018, 03:09 PM | #15 |
#buildnotbought
10877
Rep 4,895
Be sure to get the 188k model, not the 168k model because its weak.
The ETK somehow lists the 168k model for certain 2.5i x3 models and 188k for others.
04-11-2018, 03:18 PM | #16 |
Rep 151
What do you mean by etk? or rather, how can i tell what's 168k or 188k?
04-11-2018, 04:29 PM | #18 |
#buildnotbought
10877
Rep 4,895
ETK=ErsatzTeileKatalog (german for spare parts catalog, so basically realOEM or bmwfans.info but then 'official')
168K is a diff with a 168mm crown wheel and 188k is a diff with 188mm crown wheel. The K alledgedly stands for 'Kurz' (short) but I'm not sure how the K and L diffs exactly differ. I also dont know if there are optical differences between the 168k diffs and 188k diffs (without opening them up obviously). This is a 188k diff (my old one): And this is apparantly a 168k diff (advertized as from a 2.0L e85 z4 which have according to the ETK a 168k diff): Also input and output flanges differ between engine models and cars. The output flanges are relatively easy to swap, but swapping the input flange requires special care because there is a crimp bus inside the diff that is crimped by the input flange nut. So swapping out those input flanges requires a good understanding and feel on how much drag/pretention a bearing must have or you have to have a very special torque wrench that measures in Ncm. Getting this wrong will destroy your diff
