06-01-2010, 09:14 PM | #1 |
Free Thinker
16556
Rep 7,447
Turn signal indicator too quiet
Think it would be difficult to hook a louder beeper to the turn signal? My turn signal won't auto-cancel unless I really pull a full 90 degree turn. I've caught myself driving with it on after turning several times. I'm afraid I'll not notice it someday and someone will pull out in front of me thinking I was going to turn.
Any thoughts?
06-01-2010, 10:35 PM | #3 |
Free Thinker
16556
Rep 7,447
I tried keeping my hand on it so I remember to turn it off. But sometimes when I'm approaching an on- or off-ramp I flip it on so the trucker behind me knows I'll be slowing. Then I forget it's on. I just wish it didn't take a 90 degree turn to get it to cancel.
06-02-2010, 07:49 AM | #5 |
Rep 1,143
Sorry, but doesn't the blinking light in your instrument cluster attract your attention? IIRC, the turn-signal click is actually louder in the Z4 than most of the rental cars I've driven.
Usually when I lane change or make slight turns (like onto an on ramp) I just lift/push the lever far enough to trigger the signal without getting it to lock, and hold it for a couple of blinks. You can also get your dealer to program it so that doing so triggers the signal to flash three times, even if you release the lever. The previous owner did that on the M and it's really a nice convenience. |
06-02-2010, 08:03 AM | #6 |
Rep 11,665
Mine is programmed for 3 pulse lane change, I love it.
The sound level is a complete none issue for me, I've heard louder ones & dislike them.
06-02-2010, 09:31 AM | #7 |
Rep 1,110
ive got the 3 blink as well, i use it everyday
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 * '14 Jeep Grand Cherokee Overland Hemi... No more snow for the M! |
06-02-2010, 09:48 AM | #8 | |
Free Thinker
16556
Rep 7,447
I asked the dealer about setting it to cancel after three blinks. They said my '06 is not equipped for that. I was just hoping there was some fairly easy way to tie a beeper into the system. Probably not, though. Guess I'll just have to get in the habit of keeping my hand on the stalk through the turn or lane change.
06-02-2010, 10:05 AM | #9 | |
Rep 11,665
I had it on my 06 M Roady
06-02-2010, 10:34 AM | #10 |
Free Thinker
16556
Rep 7,447
Is it a specific option? Isn't called Lane Change something or other? If it is an option, it should be easy enough to check if mine is so equipped.
06-02-2010, 10:55 AM | #11 |
Rep 11,665
No, it's not an option.
It's in the car memory settings, just needs enabling.
06-02-2010, 11:27 AM | #12 |
Rep 631
Yes, it is not an option but can be enabled on all Z4s I believe. I think I could have even enabled it on my '04 M3 (never did though, didn't want to have to deal with the dealer....)
It is only for when you just move the lever in one direction or the other to signify a lane change as if you were on the freeway changing lanes; when you do not move the lever past the detent where it then stays on. I do not believe it will disable the turn signal when you move the lever past the detent as in the situation when you are sitting at an intersection getting ready to make a turn and have turned your turn signal on. You could get the stealer to make this option active for you, but I don't think it is going to fix your particular problem. When the turn signal is active from moving the lever past the detent, so that the signal is on until you make a turn or push the lever back, I do not think there are any mods available to defeat the turn signal. |
06-02-2010, 11:34 AM | #13 |
Rep 11,665
^it's not an option in the sense that it has to be ordered.
It's standard in all cars as a selectable software option, programmed by the dealer or indi tech.
06-02-2010, 11:54 AM | #14 |
Rep 631
