05-28-2010, 03:11 PM | #1 |
Rep 316
Best way to remove sap?
Another detailing question-
Any recommendations for getting sap off a waxed car? I've tried my quick detail spray without any luck. |
05-28-2010, 03:33 PM | #2 | |
Rep 15
Drives: ZHP, VR4, G35, EVO, M Coupe
Garage List 2004 BMW 330CI ZHP [0.00]
1999 Mitsubishi 300 ... [0.00] 2007 Infiniti G35 [0.00] 2007 BMW M Coupe [0.00] 2008 Mitsubishi Lan ... [0.00] |
Hey there. Excuse the crudeness of my post, I am doing so from my Blackberry. The best way to remove sap is a clay bar - it is also a detailing must have. I'm not sure how it would differ on a waxed surface. Tree sap is awful to deal with and in all likelihood you will have to rewax the surface. Here's an article I found:
04 330CI ZHP, 99 3000GT VR4, 07 G35 Coupe, 08 Evo X, 07 M Coupe
05-28-2010, 05:49 PM | #4 |
Rep 15
No problem! Hope it helps or answers your question.
05-28-2010, 06:50 PM | #5 |
Rep 1,143
Depends on the sap, but the trees at work happen to spray sap all over my car if I park under one so I end up with these tiny spots all over my car. Usually Optimum No Rinse will get it off if I catch it early. This is from deciduous trees -- I think saps from conifers are harder to remove.
06-01-2010, 03:23 PM | #8 |
Rep 632
If it's on there real good, yes, you will likely be looking at removing wax in the process of removing the sap. A safe, citrus-based cleaner may have to be used if it's stuck on bad. I'd try clay bar first just realize that if you are removing very much sap with a clay bar, it will in short order destroy the clay bar. In my experience, using a small amount of the citrus based cleaner will gently dissolve the sap with no effect on the paint. I just don't delay in getting a good coat of wax back on it because it definitely will remove wax.
06-01-2010, 11:00 PM | #9 |
Rep 1,543
Warm, soapy water first (after a little soak). If that doesn't work, clay. I hate sap more than I hate tar and almost as much as bug splats.
- Jeff
bosstones' flickr |
06-02-2010, 07:36 AM | #10 |
Rep 1,143
Bird poop is the worst IMO. Sometimes you get a ton of grit, and in hot weather it takes no time for the acids to etch the clearcoat even once you remove the stain.
