10-18-2021, 11:31 AM | #1 |
Rep 199
Drives: BMW Z4C 3.0si 3 pedal
2007 E86 front sway bar switch
Looking to change out the stock sway bar 2007 Z4 E86 , sport suspension. Have read about using M3 convertible 27mm units. If this is possible what years of M3 bars are interchangeable ?
Not wanting to buy aftermarket if possible. Any help is appreciated TIA |
10-18-2021, 01:33 PM | #2 |
Rep 12,567
If you have non-M don’t do it. It may fit but on full lock the bar hits the caliper, and u then you have no brakes for a moment (quick fix is to pump). I’d experience this when I was parking the car.
Ended up going with h&r front sway adjustable intended for the 3.0i/si |
