07-19-2012, 03:24 PM | #23 |
Rep 2,138
Drives: Me
From the book:
"The most important thing about the chassis of the Z4 is the high degree of precision that has been achieved. The car is nearly neutral in cornering; meaning a lack of rotation (yawing) in corners. The intervention of the DSC (Dynamic Stability Control) system comes in very late since the DSC is really a yaw control system. If it is needed at all, DSC had been designed to come in very smoothly. For more aggressive drives, the DSC system has a special DTC (Dynamic Traction Control) mode. BMW has found that with a sporty car, DSC has the potential to ruin the drivers fun. DTC will allow a little slippage without the DSC intruding. On previous BMW systems, if the DSC was turned off, there was no fail safe mode. With this new DTC mode, a little slippage is allowed by the DSC but the system will come in if the drivers gets into trouble. In other words,it allows a skilled driver to drift the car a little but the safety net is still there. The system is intelligent and reduces the target (the point the DSC will intrude) as speed increases. At higher speeds it goes into full DSC function to provide protection. It should be noted that these systems do not repeal the laws of physics and it is still possible to go into the corner entirely too fast..." |
07-19-2012, 03:56 PM | #24 |
Rep 98
Drives: '90 Porsche 941, Z4 Roadster
Thanks all for the info, definitely cleared up my questions! Without reading the manual (because I'm stupid and impatient), I've always assumed that when DTC was on in the gauge cluster then traction control was on and that was it.
07-19-2012, 04:04 PM | #25 |
1821
Rep 5,337
I would just like to point out...
While the DSC and DTC systems are quite advanced, they do not repeal the laws of physics. While they "extend" the threshold of what the car is capable of doing, vehicle dynamics is vehicle dynamics. When your sideways momentum exceeds even the limited grip available to your tires, no amount of DSC/DTC intervention is going to keep you going straight. So it's fine and dandy that you or anyone here keep their DSC or DTC on when they're driving. But it's by no means bullet-proof. The only sure-fire way to keep your car going straight, is to learn the skills to keep the car going straight. Believe me, you CAN get sideways even with DSC on. With enough power and speed (and bad enough driving) you can overwhelm even the best of German engineer can offer. While it's nice to have the extra layer of protection with electronic driving aides, I am a firm believer that you can ALWAYS learn to be even safer IF you have the proper car control skills. In addition, I believe DSC is capable of making even the average driver look like professional racers. The end result is that, since the "limit" is moved so far higher, when you do exceed that limit of what driving aides can intervene, it's already way past the possibility of recovery and the average driver won't know what to do when that happens.
07-19-2012, 04:15 PM | #26 | |
Rep 98
When looking at people (always young) that wrecked their cars going fast, ALL of them thought they were good drivers, aka bulletproof. I also found it interesting that the Z4 seems to hide its boundaries. By that I mean it's hard to know where the edge of control is. You think everything is ok so you push it harder and then without warning you cross that line |
07-19-2012, 04:21 PM | #27 | ||
Rep 881
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
07-19-2012, 06:55 PM | #28 | |
tosser
31
Rep 988
'07 MCoupe lots of mods |
07-19-2012, 07:00 PM | #29 |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
07-19-2012, 10:31 PM | #30 |
Rep 149
DSC off, all the time. I'd rather overdrive the car and know about it sooner than have the electronics cover up little or driving. Especially in slippery conditions, I'd rather have control of my rear wheels than leave it up to the computer to start cutting throttle or breaking (driving in the snow is a good example). The z4m is also the first car I've tracked with traction control and after just a few laps it was off for good since it seemed to be flashing all the time and just wanted to keep the car tight rather than letting it track out of turns with the power down.
anyone know of a way to default dsc to off? |
07-25-2012, 12:43 PM | #32 |
Rep 1,772
Drives: 2007 Z4M Coupe
07-25-2012, 02:13 PM | #33 |
Rep 1,107
[QUOTE=Mueller944s2;12356642... it's hard to know where the edge of control is. You think everything is ok so you push it harder and then without warning you cross that line[/QUOTE]
Exactly. I've had my roadster over year now and it still scares me more than I'd like. Its capabilities are very high, but on public roads those trees and other obstacles are really going to hurt right after you're quickly over the edge and say "oh sh*t". DSC off? Don't think so. The odds are against you that it's going to bite you one day. It is a thrill to drive though. In a Boxster I'd be saying "wow this is faster and my pants aren't wet", while in the M I'm saying "wow, this is more fun". |
07-26-2012, 01:29 PM | #34 |
Rep 98
Well I tested it out both on and off and I have to say my opinions are changed a bit. With it off it just can't take much abuse at all, the back end doesn't swing well it just skips a little bit and in the rain, like yall said, its harder to control. With it on it's just glued to the road. It can't take the turns as fast as I would like with the systems on or off due to lack of weight in the back of the car, but I was impressed none the less with its amazing handling capabilities! However, at the end of the day I feel much more comfortable with my stability control being my right foot and knowing that I can easily swing my transmission around a corner whenever the 911s wanna play.
07-26-2012, 03:28 PM | #35 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
IMHO I'm a decent driver. DSC OFF! and a freshly sprinkled wet,slick road was not good
for me. I leave it on all the time now. That rear end will get out quick. Real quick. http://www.zpost.com/forums/showthre...ht=BAD+WEEKEND
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings Last edited by mousitch; 07-26-2012 at 06:16 PM.. |
07-26-2012, 03:55 PM | #36 |
Rep 924
Noob question: How do I activate "DTC Mode"? All I'm seeing is a DSC button that's on or off.
I always turn DSC off. The rear has never slipped out where I'm dumbfounded about how the car got away from me. You really need to consciously do it, otherwise you're not a very skilled driver at all IMHO. However, wet roads are a different story -- DSC always on. You're asking for it otherwise. At my first track day last month, I left it on for obvious reasons. Near the end of the day, I turned it off and realized a very obvious boost of speed through certain corners. But I can certainly understand how the car can get away from you in the heat of a track moment.
07-26-2012, 04:04 PM | #37 | |
Rep 98
07-26-2012, 04:05 PM | #38 | |
Rep 98
07-26-2012, 04:06 PM | #39 |
Rep 1,066
Drives: 2015 X5 50i M Sport
only non-M gets the DTC
2019 Cayenne Turbo
Gone but not forgotten: 2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport |
07-27-2012, 12:29 PM | #42 |
Rep 238
This is a very interesting discussion. I am a bit old school as I come to an M from years of driving an MGB. No traction control at all - you just have to drive it right.
My experience also points to something no one has mentioned in this equation - tires. I can tell you that about 30 years ago the last thing you wanted on your MGB was some Michelins. They stuck like glue up to some point and then you were all over the road. Conversely, a set of Yokohamas would allow you to approach the limit and get a little wiggle in your rear end to let you know you were close. So, what does everybody think about different tires have different effects, DSC on OR off? |
07-27-2012, 03:02 PM | #43 | |
///M-fanatic
193
Rep 3,885
In fact, my MR2 didn't even have the ABS haha. Cars nowadays are filled with SO MUCH ingenuity and tech that they're so easy to drive in comparison. But on the flip side, it's probably because of the advancements in automobiles and the trickling down of new tech that cars are now able to go faster, and that's what gets people; going too fast without proper skill/training to keep the car under control. Honestly, with good tires, I can't even slide out my rear with DSC off unless I really try. Even under spirited driving, I'm so used to taking the smoothest/straightest line through turns that the tires barely even chirp. On rainy days, I turn DSC off on purpose sometimes just so I can slide the rear out for some fun. But again, only where there's wide open space and no pedestrians |
07-27-2012, 03:59 PM | #44 |
Rep 541
Drives: 2022 X3MC
When I bought the car, the rear tires that came with it were not good tires. Any wet condition, if I wasn't careful the rear end would slip out and also break traction 1st & 2nd with aggressive throttle. This is with dsc on.
I only drive without dsc or dtc on roads I know in dry conditions if I want to spiritedly drive, otherwise it's on all the time. Once I change out all 4 tires, I will start experimenting.
'00 328i // Sold
'04 Z4 3.0i // Sold '22 X3MC LCI |
