11-15-2011, 03:55 PM | #1 |
Rep 31
WTB: Volks TE37SL for Z4M coupe
Hello all, I have been watching this forum for a month now and am looking for a set of TE37 SL's for my z4m. Anyone willing to sell? Since i am new and cant pm, crfine888, i need some help with the offsets and specs of the SL's you currently have on ur ride. What is your car lowered on? I love your setup btw Truly an amazing transformation. I got my APR splitter after seeing yours! Thanks for looking and your time! Cheers |
11-15-2011, 04:43 PM | #2 |
548
Rep 5,695
Chris had the 18x9.5" ET22 and 18x10.5" ET20 Volk Racing TE37SLs, but he has quite a bit of fender work done along with negative camber dialed in to fit. Hopefully that helps you out. Let me know if you have any other questions about TE37SLs, we have a couple sets available
11-15-2011, 10:23 PM | #3 | |
Rep 31
Was the fender work in front alone or the back also? Do you have any size that would fit without trouble? Thanks! |
11-16-2011, 09:44 AM | #5 |
DHS
204
Rep 4,013
Drives: 2023 M4, 2020 Land Rover
That is not aggressive at all for the Z4M/ E46 M3 IMO. Like I have said I ran the 18x9 +22 and did not rub lowered on my M3 or Z4M. +35 would be awesome. But remember most of us run more negative front camber than the average Z4M driver. Especially with a front and rear drop of more than 2 inches.
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
11-16-2011, 03:39 PM | #9 | |
548
Rep 5,695
The TE37s come in 18x8.5", 18x9.5", and 18x10.5". The Z4Ms I've seen around here go with either 18x9.5" all around or 18x9.5" and 18x10.5" staggered. |
11-16-2011, 03:49 PM | #10 | |
Rep 31
Are these sizes in stock? |
11-16-2011, 03:54 PM | #11 | |
DHS
204
Rep 4,013
I would go with: 18x8.5 +35 18x9.5/10.5 +22-+25 I would also probably have 2 sets of wheels if you track the car a lot.
11-16-2011, 04:02 PM | #12 | |
Rep 31
11-17-2011, 10:42 AM | #13 | |
Rep 2,747
I am running KW clubsport suspension. I had 18x9.5 et22 w/ 255/35 rubber and 10x10.5 et20 w/ 275/35 rubber For the front I had to run -3.0 degrees camber and max out my caster. no fender rolling was needed, but I did trim the plastic fender liner a bit. For the rear, just some fender rolling and pulling is needed. This worked but ended up being more show than go for my purposes. If you are looking for what is more functional, I would consider more conservative offsets/sizes as others have mentioned cheers, Chris
11-17-2011, 12:35 PM | #14 | |
Rep 31
What wheels do you have on at the moment? I cant seem to find any info on your mod thread. Ohh and that diamond black TE37 SL |
11-17-2011, 12:54 PM | #15 | |
DHS
204
Rep 4,013
11-17-2011, 01:16 PM | #16 |
548
Rep 5,695
It's a secret
